July 3, 200818 yr Ashampoo Burning Studio 6 FREE v6.6.1.0Info: Simplicity in operation, small, and full of features, this is simply the best CD-DVD burning program I have ever used --much easier to use than CDburnerXP, Nero, Roxio, etc. Plus, this particular version is completely free. BuildDate: Jul-03-2008MD5: E072547C982216E15D9A9C77CCF8F029Size: 6,257 KBAuthor: AshampooWebsite: http://www.download.com/Ashampoo-Burning-S...4-10776287.htmlInstalls To: %programfiles%\Ashampoo\Ashampoo Burning Studio 6Shortcut: %AllUsersProfile%\MultimediaNotes: Be warned, this is my very first true AddOn. I built it with the help of Ricktendo64's Tutorial Videos on a VM with Kal's CandyPack. It's been tested extensively in VirtualBox with no problems. This AddOn designed to NOT open up a nagging webpage on install, prompt for updates, nor create any annoying desktop shortcuts. Changelog:v 0.82 Initial Release Edited July 3, 200818 yr by FreeMortal
July 3, 200818 yr Thank you.Edit : Small request. Can you change, or tell me how I change, the start menu shortcut from Multimedia to Ashampoo. Works great BTW. Edited July 3, 200818 yr by bigb
July 3, 200818 yr Thank you.Edit : Small request. Can you change, or tell me how I change, the start menu shortcut from Multimedia to Ashampoo. Works great BTW.go into the inf and search for this[burningStudio6Free.AddShortcut]Name ="Burning Studio 6",0x00000008,23CmdLine =16422,"Ashampoo\Ashampoo Burning Studio 6","burningstudio.exe"SubDir ="Multimedia"change SubDir Multimedia with Ashampooi hope i can help
