UtCollector Posted April 11, 2009 Share Posted April 11, 2009 (edited) Here is ImgBurn V2.5.6.0English only. You can download other language files ad there homepage.Features:ImgBurn is a lightweight CD / DVD / HD DVD / Blu-ray burning application that everyone should have in their toolkit! * Read - Read a disc to an image file * Build - Create an image file from files on your computer or network - or you can write the files directly to a disc * Write - Write an image file to a disc * Verify - Check a disc is 100% readable. Optionally, you can also have ImgBurn compare it against a given image file to ensure the actual data is correct * Discovery - Put your drive / media to the test! Used in combination with DVDInfoPro, you can check the quality of the burns your drive is producingV2.5.6.0:Homepage:Install from: True addonMD5 hash: 207ef3a27744ee3b7302c51f64c0dcd5File Size: 2,96 MB (3.110.580 bytes)Download here:Change log: Edited December 28, 2011 by UtCollector Quote Link to comment Share on other sites More sharing options...
qwesta Posted April 12, 2009 Share Posted April 12, 2009 thank you, but wish one could install this via *.inf file. Quote Link to comment Share on other sites More sharing options...
UtCollector Posted April 12, 2009 Author Share Posted April 12, 2009 thank you, but wish one could install this via *.inf file.Well you can..Just unzip the file. Use a cabtool to uncab the *.in_ file Cab tool can be found in some update packs here. Ore Google.If you want to install the true *.inf from within windows try the next nice trick.Open the *.inf filegot to:[sourceDisksNames.x86]1="ImgBurn Files","ImgBurn.cab",,"i386"change to:[sourceDisksNames.x86]1="ImgBurn Files","ImgBurn.cab",,"./."Now the install will go without asking for the lacation of the *.cab file. Quote Link to comment Share on other sites More sharing options...
LUZR4LIFE Posted July 20, 2009 Share Posted July 20, 2009 Changed [Release] to [Addon] and added to complete addon list Quote Link to comment Share on other sites More sharing options...
UtCollector Posted December 28, 2011 Author Share Posted December 28, 2011 Updated to ImgBurn V2.5.6.0 Quote Link to comment Share on other sites More sharing options...
