[Addon] Microsoft .NET Framework V3.5 SP1 FULL - 20131008
includes:
dotNet Framework 2.0 SP2
KB958481 - Application Compatibility Update
KB976569 - Update for the .NET Framework 2.0 SP2 forward compatibility
KB976576 - Rollup Update
KB976765 - ASP.NET update
KB980773 - NCL update
KB2604092 - Vulnerabilities in .NET Framework Could Allow Remote Code Execution
KB2729450 - Vulnerabilities in .NET Framework Could Allow Remote Code Execution
KB2742596 - Vulnerabilities in .NET Framework Could Allow Elevation of Privilege
KB2789643 - Vulnerabilities in .NET Framework Could Allow Elevation of Privilege
KB2833940 - Vulnerabilities in .NET Framework and Silverlight Could Allow Remote Code Execution
KB2836941v2 - Compatibility and Reliability Update
KB2844285v2 - Vulnerabilities in .NET Framework and Silverlight Could Allow Remote Code Execution
KB2863239 - Vulnerabilities in .NET Framework Could Allow Spoofing
dotNet Framework 3.0 SP2
KB958483 - Application Compatibility Update
KB976570 - Forward Comptibility Update
KB976769 - WCF update
KB977354 - This update will disable the Web Browser ActiveX control (WebOC) when running WPF XAML Browser Applications (XBAPs) in the Firefox browser in partial trust
KB2756918 - Vulnerabilities in .NET Framework Could Allow Elevation of Privilege
KB2832411 - Vulnerabilities in .NET Framework and Silverlight Could Allow Remote Code Execution
KB2861189 - Vulnerabilities in .NET Framework Could Allow Remote Code Execution
dotNet Framework 3.5 SP1
KB953595 - The Visual Basic compiler (Vbc.exe) may use 100 percent of the CPU resources when you build a .NET Framework 3.5-based application that has many assemblies and references
KB958484 - Application Compatibility Update
KB960043 - Dual Branch Servicing
KB963707 - Framework Assistant 1.0 for Firefox
KB982306 - ADO.NET Data Services Update
KB2604111 - Vulnerabilities in .NET Framework Could Allow Remote Code Execution
KB2736416 - Vulnerability in Open Data Protocol Could Allow Denial of Service
KB2836940 - Compatibility and Reliability Update
KB2840629 - Vulnerabilities in .NET Framework and Silverlight Could Allow Remote Code Execution
KB2861697 - Vulnerabilities in .NET Framework Could Allow Remote Code Execution
Other Updates
KB951847 = Microsoft .NET Framework 3.5 Family Service Pack 1
KB959209 = KB958481 + KB958483 + KB958484
KB971276 - You receive incorrect print output if the IPrintPipelineProgressReport interface is used in your printing application
note: if you get nagged by MU/WU for KB961118 and/or KB971314 use my Post-SP3 update pack
or one that does include them. XPSP3_QFE_UpdatePack for Windows XP Post-SP3 (user_hidden)
WIC and MSXML6 have been removed from the installer but is of no issue as they are included in Windows XP SP3.
Addon for RVMi 1.6 or higher.
Integrate this addon to run the installer at RunOnceEX.
There will be progress boxes but NO user interaction is required.
Passive mode is used since setup takes a while, this way you will know
where you are in the setup process. Final installation will take
place after OOBE and before Personalized settings occur.
Link: Addon_Microsoft.Net_Family.35SP1_ROE_20131008.7z
CRC-32: ff0b9e97
MD4: 3fd4022239b39e14bfbed7e123b186da
MD5: 71a4c2d724a8ddd9e0dc7c3f29b98e21
SHA-1: 07c7993bf8bb6072bc39dc10df66bd9e635fb67a
Date: 20131008
OS: Windows XP SP3 (x86)
If you unpack the Addon to get access to the multimode installer you'll have access to the following switches:
-ai = Silent
-ai1 = Passive
/h = displays help
Some utilities:
Aaron Stebner's .NET Framework Cleanup Utility
Aaron Stebner's .NET Framework Setup Verification Tool
dotNetFWVersionChecker.exe - .NET Framework Setup Verification Tool
Free DotNet VersionCheck Utility
Edited by user_hidden
  • Replies 57
  • Views 48.2k
even though my system to integrate with the framework is still missing the update finds
very hard to understand what you are trying to say but if you integrate this addon
you will be up to date with the frameworks with no updates offered by MU curently.
this is as well designed for winxp_sp3 ENGLISH. i would presume you would require a language pack for non-english OS.
After I built it on my system, I see you still update
if you are saying after integration you require updates by MU, than you have done
something wrong as this installer is 100% up to date.
  • 5 weeks later...
Clicked on link to download - taken to RapidShare page to create an account and then to upload files/programs - is this correct? In the past I was taken to a page to download - and to wait if not a RapidShare member - did somethign change?
Later the same day: Booted into XP Pro x64 w/SP2 using IE8 64-bit. This time the RapidShare page switched from creating an account to showing the download was available and that the free would take time to allow access; but the download worked.
Can only assume some kind of issue during previous attempt from within XP Pro w/SP3 and IE6.
Glitch or gremlin in cyberspace? Don't know but I figured I'd post the info just in case.
Edited by ChiefZeke
Is there an addon just for the latest .net updates somewhere?? (for KB2416447, 2418241,2416472/73)?? I tried the first link/download, it didnt work. It said most of the files were already there (I've already got most of the .net updates slipstreamed). I'm just after the above updates. So, I can add them. Thanks
  • 6 months later...
One quick question, If I am using nLite, where should I use it?
In svcpack or ROE? Because your post is in SVCPACK Addons forum but in your post you said RunOnceEx and also the link you provided says Addon_Microsoft.Net_Family.35SP1_ROE_20110614.7z
So basically where am I supposed to put it in nLite, SVCPACK or ROE???
just add the addon with nlite as you would integrate any addon.
it will setup and run during ROE when you are installing XP.
the dotnet 3.5 sp1 kb961118 does not included
READ THE 1st POST !
