March 18, 200719 yr Vista RTM Aero Cursors for XPComes in Normal, Large and Extra Large sizesRicks_VistaRTMAeroCursors_AddOn.rarMD5: 8038ADA5BF73820BC7E84607EA73E9B5Size: 93.7 KB
March 19, 200718 yr Hey,I don't suppose you know the registry key to set the default cursors in XP?laze.
March 19, 200718 yr Author Its not done in the registry, but in a DLLUse a reshacker and replace the cursors in user32.dll with a set of non animated curs
March 19, 200718 yr Its not done in the registry, but in a DLLUse a reshacker and replace the cursors in user32.dll with a set of non animated cursYou may as well be speaking a foreign language.laze.
March 19, 200718 yr Author Here are some that I have alredy done with the Anti-Aliased Shadowed Cursors...user32_Cursor.rarGo to system32 and copy user32.dll to someplace on your desktopOpen it in reshackerGo to Action then Update all ResourcesBrowse to user32_Cursor.res and hit OKThen CTRL+S (Save)Use Replacer to replace in system32 and Voil
March 19, 200718 yr Right,And before I do the above, I'll need to select my cursors of choice - right?laze.
January 3, 200818 yr Here are some that I have alredy done with the Anti-Aliased Shadowed Cursors...user32_Cursor.rarGo to system32 and copy user32.dll to someplace on your desktopOpen it in reshackerGo to Action then Update all ResourcesBrowse to user32_Cursor.res and hit OKThen CTRL+S (Save)Use Replacer to replace in system32 and Voil
May 18, 200817 yr how to replace the original cursors by those of Vista ?les curseurs originaux se trouvent dans user32.dll voila cet addon ne permet pas de changer les curseurs par defaut qui sont dans windows mais d'ajouter ceux de vista a xp comme la propose ricks telecharge ce fichier ressource et applique le sur user32.dll (en tenant compte que tu as deja decompresse celui que tu as dans I386 ) avec reshacker ou restorator puis sauvegarde et met lui un coup de modifype apres tu le compresse avec la commande makecab a la fin ca doit donner ca user32.dl_Here are some that I have alredy done with the Anti-Aliased Shadowed Cursors...Attached File user32_Cursor.rar ( 6.01K ) Number of downloads: 48Go to system32 and copy user32.dll to someplace on your desktopOpen it in reshackerGo to Action then Update all ResourcesBrowse to user32_Cursor.res and hit OKThen CTRL+S (Save)Use Replacer to replace in system32 and Voil Edited May 18, 200817 yr by ferigno1
May 18, 200817 yr les curseurs originaux se trouvent dans user32.dll voila cet addon ne permet pas de changer les curseurs par defaut qui sont dans windows mais d'ajouter ceux de vista a xp comme la propose ricks telecharge ce fichier ressource et applique le sur user32.dll (en tenant compte que tu as deja decompresse celui que tu as dans I386 ) avec reshacker ou restorator puis sauvegarde et met lui un coup de modifype apres tu le compresse avec la commande makecab a la fin ca doit donner ca user32.dl_merci ferigno1 !je ne pense pas que je pourai le faire,y a beaucoup de manip !sinon pourquoi pas faire un addon de remplacement comme l'addon de vista sound remplacement ?http://www.wincert.net/forum/index.php?showtopic=1643
May 18, 200817 yr OK either provide translations or take it to PM!!!Remember people this is a primarily english forum!
May 18, 200817 yr OK either provide translations or take it to PM!!!Remember people this is a primarily english forum!ok I do more post messages in french !
May 18, 200817 yr how can i set the Aero cursor as a default cursor?edit: i use nlite to include this addon. Unfortunately, after 1st boot, on the welcome page, the cursor is this aero, but after windows applying theme, the cursor changed. how could i fix this? thanks Edited May 19, 200817 yr by arepie
February 13, 200917 yr Logical answer without killing your system found Here. Edited February 13, 200917 yr by Keithy E
