[Solved] IE9- and XP-Mode Integration
I know, there is already a similar thread about the problem, but it is already marked as solved; for me it isn't!
Again is about IE9-integration and kb2719177 (obvious, IE9 has been not integrated) and also XP-Mode: all these tree are marked red in Version 1.4.0.38.
Pleas have a look at this pictures
For IE9 and XP-Mode exe-german-version) the language-column is missing and so all colummns right of Language are shifted to left, as you can see (size under Language, Architecture under Size and so on).
Whit version .36 and .37 is OK
Tomorrow I will install and have a look at the "end-product".
Have a good night.
Thiersee
Same as before, the .INI-File is always the same;
IE9-Windows-x64-deu-.exe
WindowsXPMode_de-de.exe
KB2719177
BTW:
User loginvovchyk sad v .38 is working: could be the "little" difference, how the packs are integrated?
As you see I use IE9xxxxx.EXE, he uses IE9xxxx.MSU.
Could be the actual problem be in this difference?
Regards
P.S.: I confirm the matter!
1.4.0.37: XP-Mode and IE9 have been integrated and installed
1.4.0.38: XP-Mode and IE9 have been neither integrated nor installed.
Edited by Thiersee
