[Solved] Drivers not integrated, path of IE9-LP
Hi Legolash2o,
I'm terribly sorry to give you 2 "bad news" but:
1) v40 does NOT integrate drivers (the same was in v39)
to be integrated
integrated
2) On loading .INI-file WinToolkit changes the path for IE9-LP in the .INI-file
IE9-LP
Sure, it's good for the integration, but if I add new objects (programs, drivers or whatever) and I save (obvously) the presets, this modified path wil be saved in the preset;
this is not so good: next time I load the preset, the IE9-LP is not present anymore, because temp-path has been deleted on exiting WinToolkit.
BTW:
saving windows-size: very good
giving version on title-bar: very good
Thanks.
Regards, Thiersee
Sorry, but 1 item is still not working OK (path for IE9-LP)!
v43 too is saving .INI-files always with modified path; both the .INI I save within tool and the INI the tool is saving on starting integration is the path for IE9-LP on WinToolkit-temp.
I must modify the INI by hand and write the old-path, otherwise the tool don' find IE9-LP on the next start/load.
Regards, Thiersee
It works fine, the saved INI has the original path for IE9-LP in.
If there are NO "hidden disfunctions" :D , it's perfect for me :thumbsup_anim: !
Thanks.
Edited by Thiersee
