August 5, 201213 yr Read here: http://www.wincert.n...e-one-or-error/I tried an integration, after I have read the post from McRip, but I forgot to cancel the XP-Mode-File from the update-list;the result was that WinToolkit integrated VirtualPC and the two updates, even if WinToolkit moved this three items to the Silents+SFX (see screenshots); please, have a look to the status-line.Run integrationUpdates before integrationUpdates after integrationSilent Installs + SFX before integrationSilent Installs + SFX after integrationAnd what I want to say with allt his stuff?XP-Mode must in the exceptions-list too.Regards, ThierseeP.S.: if you mean, this post is better in a new thread, please feel free to move it
August 6, 201213 yr Author Hi,Virtual PC has moved to Silent Install+SFX as "not needed" (together with two optional updates for VPC), but it has been integrated (and the two updates too) only because XP-Mode was still present in the prerequisite list; have a look to the first screenshot: the status line shows "integrating VirtualPC".
August 7, 201213 yr Author I don't see the issue, everything worked how it should. What was you expecting?This is, what I wanted to say with my post:Do you see the difference ?v52 is working for my perfect: no problems, no issues, nothing!All features I need are working.P.S.: can you mark the topic as "solved"? Thanks! Edited August 7, 201213 yr by Thiersee
August 7, 201213 yr WOW what a strange issue, glad it's gone now though.I have literally no idea what could have caused the wrong status :?
