September 15, 201213 yr I couldn't resist making a comment to the author to check out your tool http://www.howtogeek.com/124368/how-to-create-a-customized-windows-7-installation-disc-with-integrated-updates/#comment-192704
September 15, 201213 yr Author Hmm.... I just checked and it says:[Your comment is awaiting moderation and will be posted shortly.]All I said regarding the article and RT7Lite was "That’s a seriously outdated tool and you should really check out the currently supported WinToolKit: http://www.wincert.net/forum/files/file/5-win-toolkit/ "
