September 22, 201213 yr I saw this in an earlier version but had not seen it again until today.Normally when I run WinToolkit, I do it in the foreground without doing anything else.Today I was browsing the web with WT in the background working away.It's been stuck at this status prompt for over 30 minutes:"Integrating Reg [Compressing]: 51 of 69 (Change Logon Background)"I just clicked Cancel and the status bar says "Stopping, please wait..."No real movement here, either. Will force quit and reboot to try again.It's my intent to start over again in about two minutes. Is there a log I can send you?Many thanks from an appreciative user in Atlanta.MARK STRELECKI
September 22, 201213 yr Author I cleaned up everything and ran the same setup MINUS the Logon Background and she completed without hangs or errors.Will look for a log file and get it to you asap.Thanks again!MARK STRELECKIAtlanta, GA.EDIT: The log file has a lot of this in it:Description: Unable to save as JPG.Status: Filename: C:\WinToolkit\Mount\Windows\System32\oobe\Info\backgrounds\backgroundDefault.jpg | Compression: 43Exception: Parameter is not valid.Errors_120922.rar Edited September 22, 201213 yr by Mark Strelecki
