Help Needed in Custom XP CD Creation !
Hello frndz i am new to this forum. I want to change the following image that appears after fresh install of xp just before msoobe.exe launches.When windows xp automatically adjusts the resolution.post-40317-0-48134900-1348428341_thumb.ppost-40317-0-48134900-1348428341_thumb.p
No sorry ric, it's the krnl files (there's 4 of them) He seems to have tried to change to location of the progress bar.
That is EXTREMLY difficult to do and not recommended.
I know of a way to fix it and do it properly but I need to know what he has done so far...
Thank u both of u guys 4 replying. Actually I've edited all 4 of the files in sp3.cab 1:ntkrnlmp.exe 2:ntkrnlpa.exe 3:ntkrpamp.exe and 4th is ntoskrnl.exe. These are all working fine, i can see the vista progress bar at every boot but i want to edit above image somewhere in xp source. I already told you that above image appears at first boot of fresh install of xp before the oobe launches. Please help me Thank u in ADVANCE....!!!
  • 1 year later...
go to xptsp.com
there you get lbs i.e. Live boot screen.
It helps yot to integrate your wish to your current window and also with an xp cd
