Add Win Toolkit total runtime in Mount Logs\*.log
Do you mind add a simple total runtime into the log when All-In-One-Integrator finished the task?
I usually run it before going to sleep. Hence I would like to know how long it takes to run....
Or is there already an info somewhere and I have missed it (when I wake up so that I can retrieve it)?
Regards
