Whenever I remove packages using the latest beta, they aren't removed according to DISM.
Also, when I reselect the image for removal it shows all packages again as if it didn't remove (becuase DISM still reports them as being installed). Have also tried 1.4.0.77 with same problem. Any help?
Any errors messages? Are you using All-In-One Integrator or Component Remover? What does DISM say? Pending Uninstall?
Yes. I'm getting a lot of "Unable to..." log entries. Sorry, can't attach file (too big even when compressed). Using Component Removal.
Snip from log:
2012-10-23 20:51:42, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/SOFTWARE
2012-10-23 20:51:42, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/SOFTWARE, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-10-23 20:51:42, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/SYSTEM
2012-10-23 20:51:42, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/SYSTEM, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-10-23 20:51:42, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/SECURITY
2012-10-23 20:51:42, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/SECURITY, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-10-23 20:51:42, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/SAM
2012-10-23 20:51:42, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/SAM, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-10-23 20:51:42, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/COMPONENTS
2012-10-23 20:51:42, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/COMPONENTS, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-10-23 20:51:42, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/DEFAULT
2012-10-23 20:51:42, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/System32/config/DEFAULT, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-10-23 20:51:42, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Users/default/ntuser.dat
2012-10-23 20:51:42, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Users/default/ntuser.dat, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-10-23 20:51:42, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/WinToolkit/Mount/Windows/system32/smi/store/Machine/schema.dat
I think that's why DISM still shows the packages as installed...
Edited by VerizonLover
