Script at the first logon
Hi, Greetings to all forum members
I trying to do an unattended installation of Windows 7. I'd like to lunch a batch file at the first logon, in this way I silent install all my application.
I can lunch this script with RT Se7en lite, but now I'd like to use Win Toolkit because it is compatible with Windows 8
Thanks,
It's easy for Windows 7 but it's complicated for Windows 8.
I'd like to use my batch file in a Windows 8 unattended installation.
Please more advice.
Maybe I open the thread in the wrong section, I should open it in Windows 8 section
From your first post I came up as you want an unnattended Windows 7 built in Windows 8 running system.
Yes, you should started it in Windows 8 section and be more specific.
I can't help you further. If anyone knows, you'll get an answer eventualy.
