WinToolkit: integration of non-English source?
Hi,
I am new to WinToolkit and was wondering whether you could also use it to update (integrate) a non-English ISO?
--> I would like to use as source a Dutch-language (NL) Windows 7 Professional SP1 ISO, and would like to know whether the WinToolkit framework can be used to integrate it with the latest updates (e.g. McRip). Or does it only properly work with ENU sources? After searching the forum I only found threads that discussed integration of language packs into an English source.
Thanks,
S
The updates are are language independent. You can use any souce to integrate the updates.
Only Internet Explorer and some .NET Framework (not all lang) have additional language packs.
