February 26, 201312 yr Hi, i cannot get managed to get this work to install silently with installer.If i try my sfx after installer have finished and first login is passed and i rerun the pakage it installs fine. If needed if will upload the pakage somewhere. Using this in a Batch:"%cd%\setup.exe" /quiet /log "%windir%\Temp\Navision.log" /config "%cd%\Classic.xml"After trying directly via sfxmaker parameters:setup.exe /quiet /log /config Classic.xmlBoth methods with a sfx doesnt work while executed by installer, but when its finished and i rerun the pakages they install fine.source (german):http://www.grobmanschwarz.de/ms-dynamics-nav-blog/501-silent-oder-unattended-installation-fuer-dynamics-nav I have a different Problem with Sage ACT 2013... batch:"%cd%\ACTWG\setup.exe" /s /f1"%cd%\ACTWG\issconfig.iss"sfx:setup.exe /s /f1"issconfig.iss"(missing space between f1 and "iss... is correct)source (english):http://kb.sagesoftwareonline.com/app/answers/detail/a_id/30327/~/how-to-perform-a-silent-installation-of-sage-act!-premium-2013 Both dont work while installer, after firstlogin they work. Maybe someone else installing these pakages? Greetz X23 Edited March 11, 201312 yr by x23piracy
March 2, 201312 yr Author Hi, guys please can someone assist with navision 2009 i can also give you the needed files for testing.I tried it different ways and i cant get managed to install this stupid app silently. I also tried installing navision directly over its msis, if i start the msi by hand i can install everythingif i try /passive /qn /quiet or something it doesnt install... navision sucks Please help someone. Greetz X23 Edited March 2, 201312 yr by x23piracy
March 3, 201312 yr Author Hi, i have Navision working now, i dont use their full setup anymore.I just keep the CSideClient (Microsoft Dynamics NAV Classic.msi) folder and from installersi keep (ClassicClient.Local.De.msi) and (Documentation.Local.DE.msi) To have a thin navision installer you can delete the demo db: CommonAppData\Microsoft\Microsoft Dynamics NAV\60\Database\database.fbkCommonAppData\Microsoft\Microsoft Dynamics NAV\60\Database\database.fdb Create empty dummie files because setup will stop if they dont exists.I use the following batch to install:@echo offmsiexec.exe /i "%cd%\Microsoft Dynamics NAV Classic.msi" /qn /norestart SETUPTYPE=MINIMALmsiexec.exe /i "%cd%\ClassicClient.Local.De.msi" /qn /norestartmsiexec.exe /i "%cd%\Documentation.Local.DE.msi" /qn /norestartSame procedure for the RTC Client (a demo database isn't existing here) ACT 13 is still not working who can help? Greetz X23
March 3, 201312 yr Author Hi, try changing %cd% to %DVD% no %cd% is correcht iam installing over a network share no toolkit folder in setup root.
March 11, 201312 yr Author Solved, there was a bug in my customized (cleanup) navision installation source.I dropped ACT 2013 from silent installers. Greetz X23
