March 4, 201312 yr I got error with v1.4.1.15 &1.4.1.16 when finalized updates integration... Dates: Descripción: Stopped workingFirma con problemas: Nombre del evento de problema: APPCRASH Application Name: WinToolkit.exe Application Version: 1.4.1.16 Application Timestamp: 5133ea18 Fault Module Name: KERNELBASE.dll Fault Module Version: 6.1.7601.22178 Fault Module Timestamp: 50b99994 Exception Code: e053534f Exception Offset: 000000000001a53d Versión del sistema operativo: 6.1.7601.2.1.0.256.48 Id. de configuración regional: 3082Lea nuestra declaración de privacidad en línea: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0c0a Log:[2164] Caller did not request sparse mount[2164] Mounting new image.Wim: [C:\temp6\Install.wim]Image Index: [3]Mount Path: [H:\WinMount][2164] Wimserv process started for guid 9123c0d8-a18e-4000-9627-c88903bf9fe3. Id is 3388[3388] [ INFO ] ImageUnmarshallHandle: Reconstituting wim at C:\temp6\Install.wim.[3388] [ INFO ] Mounted image at H:\WinMount.*AIO#UpdatesC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2670838-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2533623-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2729094-v2-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2786081-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2803759-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2803752-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2801453-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2800422-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2800789-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2800213-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2799406-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2800170-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2799360-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2799035-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2798787-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2798286-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2797918-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2797789-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2796647-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2796725-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2796313-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2794119-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2790817-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2790113-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2790804-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2789645-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2781049-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2780130-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2778344-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2693010-v2-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2732673-v3-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2524732-v2-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2591271-v2-x64.msuC:\temp\Windows 7 Toolkit\McRip\McRip Windows 7 x64\Windows6.1-KB2459530-v4-x64.msu#OptionsCompatibility CheckCreate BackupsEnable CMDIntegrate 'HDC' Drivers (boot.wim)Integrate 'SCSIADAPTER' Drivers (boot.wim)Integrate 'SYSTEM' Drivers (boot.wim)Prepare DriversPrompt AddonsPrompt DriversPrompt GadgetsPrompt SilentPrompt ThemesPrompt UpdatesPrompt WallpapersRebuild ImageShow Browse DialogShow Duplicates Regards...;-)
March 4, 201312 yr Author With v1.5.0.1 I don't get error... (but one update don't integrate) Edited March 4, 201312 yr by alfreire
March 5, 201312 yr About Windows6.1-KB2670838-x64.msu there is sometimes trouble and if it's the case try do not install this update: http://www.winbeta.org/news/botched-update-kb2670838-windows-7-resulting-bsod-microsoft-working-fix Microsoft recently released an update, KB2670838, for Windows 7 and it was slated to prepare the operating system for Internet Explorer 10. Unfortunately, some users are reporting a BSOD thanks to this update. Microsoft is aware of this issue and is investigating.Microsoft released a "platform update" for Windows 7 (KB2670838) on February 26th which was to "resolve issues in Windows." This update was considered a "feature pack" and was a pre-req for Internet Explorer 10, which was released for Windows 7 that same day. The update was supposed to improve the features and performance of Direct2D, DirectWrite, Direct3D, Windows Imaging Component (WIC), Windows Advanced Rasterization Platform (WARP), Windows Animation Manager (WAM), XPS Document API, H.264 Video Decoder, and JPEG XR codec. Edited March 5, 201312 yr by myselfidem
March 5, 201312 yr Author About Windows6.1-KB2670838-x64.msu there is sometimes trouble and if it's the case try do not install this update: http://www.winbeta.org/news/botched-update-kb2670838-windows-7-resulting-bsod-microsoft-working-fixThanks, friend...Regards... ;-)
March 5, 201312 yr I don't know if IE10 will installed without this update ! Edited March 5, 201312 yr by myselfidem
March 6, 201312 yr How to obtain prerequisite updates for Internet Explorer 10 for Windows 7 that fail to install: http://support.microsoft.com/kb/2818833/en-us KB2670838: A platform update is available for Windows 7 SP1 and Windows Server 2008 R2 SP1This update provides improved features and performance in Windows 7 SP1 and Windows Server 2008 R2 SP1. It includes updates to the following DirectX components: Direct2D, DirectWrite, Direct3D, Windows Imaging Component (WIC), and Windows Advanced Rasterization Platform (WARP). Additionally, it includes updates to the Windows Animation Manager (WAM), the XPS Document API, and the MPEG-2 Video Decoder. After you install this update, you may have to restart your computer.Note If this update is uninstalled, Internet Explorer 10 will also automatically be uninstalled.
