March 16, 201313 yr Hi, i have two entry in my automatic install list:Microsoft Malicious Software RemovalMicrosoft Malicious Software Removal DefinitionsI wanted to update MMSR from 4.17 to 4.18 so i removed the 4.17 entryand tried to add the same again but with 4.18 binary. Then WTK tells me this entry allready exists. Iam sure this is related to the Microsft Malicious Software Removal Definitions,the string starts exactly the same but has " Definitions" added. It seems WTK isn't checking the complete string, it also matches strings thatstarts same but are not really the same So i added the new 4.18 with a little changed string and if it's added i can giveit back the right name "Microsoft Malicious Software Removal" Maybe the string check is set to contains and not to equal. @Lego please fix. EDIT: WTK 1.4.1.15 Greetz X23 Edited March 16, 201313 yr by x23piracy
March 18, 201313 yr Author Hi, Have you tried v21? no but you know about that bug and it's fixed in 21? I will try. Greetz X23
