March 29, 201313 yr How can I make 2 DVDs with WinToolkit-AIO, one for Window 7 and one for the programs, to get my workflow so: 1) I install win7 unattended with some SFXs (Framework 4.5, VC and some KBs)2) When Wintoolkit-Installer has installed the couple of programs, I get a message like "Insert program-DVD",3) WinToolkit-Installer does his job and if it has finished, I get another message like "Insert Win7 DVD again" (if necessary), so that the installation will be automatically completed. Can you understand my problem? Did I explain it clearly? I will generate installation-media for my syster in Italy so simple as possible and I don't know, if the DVD-Drive can work with dual layer DVDs (she has not the know-how to control that); I do not want to split the DVD too!Is this possible in WTK or I have to use extrenal programs? TNX, Thiersee Edited March 29, 201313 yr by Thiersee
March 29, 201313 yr Author Why not use a 20-30Gb flash drive?Because my sister does not have enough know-how to do that on my directions by phone; she lives in Italy, I live in Austria (500 km).
March 29, 201313 yr Author You could use WPIW for the 2nd disc.What's that? Edit:OK, I found it.TNX Edited March 29, 201313 yr by Thiersee
