SFX not installing properly
Hello guys,
i recently discovered Wintools and I am planning to use it along with Windows Distrubtion Tools (on a SBS2008) to distribute a customized Windows 7 Professional image over the network to about 30 clients.
Everything worked out quite well (integrating updates, addons), except one thing: SFX files.
I successfully made some SFX files for MS Office, Adobe Reader & Flash and a few other tools (they all work silent and unattended when run manually), but somehow the Wintool Installer cant find the files or smth.
See the error in the attached pictures.
What did I do wrong?
Thanks for your help in advance!
Hello and welcome,
It seems the sfx aren't found by WinToolkit. Are they on the iso (in WinToolkit_Apps folder) ?
Are you using the latest version of WinToolkit ? (1.4.1.27)
Also, post you session ini so we can see if there is something wrong. (in Last Sessions folder )
Hello, thanks for the warm welcome :)
Yes, i use the .27 version.
That is exactly what i guessed too. THe problem is: there is no ISO file. I thought Wintoolkit integrates the installers to the .wim file?
I use the Windows Deployment Server which allows me to deploy the .wim files over the network.
ini:
*AIO#AddonsW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\Addons\Reapers.VLC.Media.Player.2.0.6.0.x64.Windows7.AddOn.WAW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\Addons\Reapers.7.Zip.9.30.Windows7.or.8.AddOn.WAW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\Addons\Reapers.Notepad2.v4.2.25.856.Windows7.or.8.AddOn.WA#Silent InstallsKB2603229::N/A (Not Needed);NO;193.42 KB;W:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2603229-x64.msu;Always InstalledReapers.Dot.Net.Framework.4.5.AIO.x64::;NO;141.30 MB;W:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\Addons\Reapers.Dot.Net.Framework.4.5.AIO.x64.exe;Always InstalledAdbeRdr11003_de_DE_silentinstaller::;NO;45.94 MB;W:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\AdbeRdr11003_de_DE_silentinstaller.exe;Always InstalledGoogleChromeStandaloneEnterprise::;NO;33.49 MB;W:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\GoogleChromeStandaloneEnterprise.exe;Always InstalledUltraVNC_10962_silentinstaller::;NO;2.71 MB;W:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\UltraVNC_10962_silentinstaller.exe;Always InstalledOffice2010_silentinstall::;NO;1.46 GB;W:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\Office2010_silentinstall.exe;Always InstalledReapers.Adobe.Flash.Player.ActiveX.11.7.700.224::;NO;16.45 MB;W:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\Reapers.Adobe.Flash.Player.ActiveX.11.7.700.224.exe;Always InstalledReapers.Adobe.Flash.Player.Plugin.11.7.700.224::;NO;17.03 MB;W:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\addons+silentInstall\Reapers.Adobe.Flash.Player.Plugin.11.7.700.224.exe;Always Installed#TweaksAdd 'Open CMD here' to Folder Context-menuAdd 'Open Elevated CMD here' to Folder context-menuAdd 'Task Manager' to desktop context-menuShow 'Computer' on DesktopOpen NFO files with notepadFaster Browsing in IE IE Homepage::www.holger-clasen.deLaunch Internet Explorer in Separate ProcessWhen a New tab Opens::'New Tab' PageDisable User Account ControlDisable Automatic Restart on BSOD#UpdatesW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2851149-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB911589-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB917607-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB949843-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB967351-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB972959-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB976042-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB982018-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB982559-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2276594-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2394535-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2401553-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2417168-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2427341-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2443643-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2446607-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2456741-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2457458-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2461631-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2462182-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2465285-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2466048-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2466493-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2467167-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2472264-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2475491-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2477932-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2479943-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2480641-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2480994-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2483564-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2486635-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2486644-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2487292-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2493006-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2493989-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2495313-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2495786-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2496898-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2502789-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2503784-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2506014-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2506628-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2506928-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2508120-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2509318-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2511455-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2514642-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2516889-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2519400-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2519735-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2520487-v4-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2521416-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2521624-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2524732-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2524977-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2526629-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2529781-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2529825-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2535158-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2536840-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2537203-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2538047-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2540175-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2541014-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2545561-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2546868-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2549067-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2549079-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2550648-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2554231-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2554859-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2554876-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2555189-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2555392-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2555948-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2560656-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2561821-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2563227-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2564958-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2569389-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2570947-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2575866-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2575928-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2577968-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2578214-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2579686-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2582679-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2584475-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2584577-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2588507-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2591271-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2591857-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2599437-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2600100-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2600484-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2603203-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2604115-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2608658-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2612905-v4-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2613988-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2614066-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2614892-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2615327-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2615701-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2616332-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2616386-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2616879-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2618301-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2618535-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2618640-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2619234-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2619260-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2619836-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2620704-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2621440-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2624868-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2625737-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2627273-v4-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2627489-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2631813-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2635500-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2636056-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2636963-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2638018-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2639043-v5-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2639077-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2639320-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2640148-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2640472-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2641618-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2641634-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2642357-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2643719-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2644491-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2645594-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2645610-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2645640-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2647753-v4-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2647878-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2648039-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2649904-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2652029-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2653312-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2653956-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2654428-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2659158-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2659262-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2660075-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2660649-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2660677-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2661796-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2662288-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2662585-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2664203-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2665720-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2668395-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2674365-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2674705-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2674913-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2675275-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2675611-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2675806-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2680097-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2680243-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2682814-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2683484-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2683913-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2684681-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2684982-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2685088-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2685811-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2685813-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2685889-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2685893-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2686369-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2686795-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2687799-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2687862-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2690528-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2690533-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2691156-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2693187-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2695207-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2696739-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2697479-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2697645-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2697738-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2698888-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2698957-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2699779-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2699780-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2700336-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2701239-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2701851-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2701894-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2703639-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2703902-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2704299-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2704377-v6-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2705219-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2706051-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2707135-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2707157-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2707589-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2708857-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2710594-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2710832-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2712331-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2712561-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2715992-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2717045-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2718646-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2718654-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2718704-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2718841-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2719248-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2719305-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2719594-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2719857-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2720568-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2721259-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2722729-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2724133-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2724137-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2725604-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2727107-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2727118-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2727324-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2727528-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2728379-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2729452-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2729608-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2732072-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2732500-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2732840-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2733955-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2735209-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2736233-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WINDOWS6.1-KB2736422-X64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2736469-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2736782-v3-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2738898-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2740180-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2740232-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2741416-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2742185-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2742483-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2743148-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2746119-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2750692-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2752407-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2754704-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2755105-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2755625-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2756198-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2756263-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2756651-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WINDOWS6.1-KB2757638-X64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2757817-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2760730-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2763342-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2765067-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2765546-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2767652-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2767671-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2768486-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2768494-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2768523-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2769121-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2769359-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2769791-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2770660-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2775511-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2779272-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2780130-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2780410-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2780444-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2781049-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2782486-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2783429-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2784148-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2786464-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2787046-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2790804-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2791372-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2794422-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2796313-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2796725-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2796764-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2797749-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2797789-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2797822-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2797918-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2798040-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2798670-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2798787-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2799360-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2799406-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2799464-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2799925-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2799926-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2800170-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2800422-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2800789-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2801244-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2801423-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2801453-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2801662-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2803752-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2803759-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2804579-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2807716-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2808693-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2809097-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2809808-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2810177-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2812463-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2815716-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2815853-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2818604-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2819485-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2820197-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2820331-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2820467-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2821049-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2821230-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2823655-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2824066-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2824408-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2824546-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2824560-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2826164-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2826910-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2827870-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2829069-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2829262-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2829537-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2830290-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2830598-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2831013-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2831014-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2831206-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2832248-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2832829-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2833001-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2833914-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2834548-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2834911-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2834976-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2835429-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2835595-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2836373-v4-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2836445-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2836502-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2836942-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2836943-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2837108-v4-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2840947-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2842986-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2845626-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2846340-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2847018-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2847077-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2847521-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2847635-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2848224-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2848576-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Windows6.1-KB2848802-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2845690-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2446710-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2478662-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2492386-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2534366-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2545698-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2547666-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2556532-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2619339-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2639308-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2644615-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2667402-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2676562-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2679255-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2685939-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2698365-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2709715-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2709981-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2724197-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2726535-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2732059-v5-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\WINDOWS6.1-KB2742599-X64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2749655-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2750841-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2753842-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\WINDOWS6.1-KB2756921-X64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2761217-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2762895-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2773072-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2786400-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2789645-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2790113-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2791765-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2798162-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2799494-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2807986-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2808679-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2813170-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2813347-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2813430-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2813956-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2823180-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2834140-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2839894-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\WU_Satisfy\Windows6.1-KB2840149-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-Core-TopLevel-x64.cabW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-ActiveX-x64.cabW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\Windows.Update.Agent\7.6.7600.256\cabs\WUClient-SelfUpdate-Aux-TopLevel-x64.cabW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\KB947821.System.Update.Readiness.Tool\Windows6.1-KB947821-v27-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2786081-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2533623-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2670838-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2729094-v2-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\IE10\Prerequisites\Windows6.1-KB2731771-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\IE10\IE10-Windows6.1-KB2718695-x64.cabW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\IE10\Updates\IE10-Windows6.1-KB2859903-x64.msuW:\EDV\Projekte\2013 Windows7-Migration\Win 7 64bit - custom Image\Updates\McRip Windows 7 x64\Additional\IE10\Updates\IE10-Windows6.1-KB2838727-x64.msu#OptionsCompatibility CheckCreate BackupsIntegrate 'HDC' Drivers (boot.wim)Integrate 'SCSIADAPTER' Drivers (boot.wim)Integrate 'SYSTEM' Drivers (boot.wim)Prepare DriversPrompt AddonsPrompt DriversPrompt GadgetsPrompt SilentPrompt ThemesPrompt UpdatesPrompt WallpapersRebuild ImageShow Browse Dialog
Edited by HC_TM
So here lies your problem. WinToolkitRunOnce search for a folder (by default it is WinToolkit_App located in the root of your work folder), not in the wim file.
As seen in your second image, you can also manually point to an other location if the folder is not found.
I'm not familiar with installations over network, so I let others respond more thoroughly. Maybe using Windows Post Install Wizard (WPIW) instead of WinToolkitRunOnce can help.
Integrate the setupcomplete. Sample script cmd:
@echo off
START /WAIT %windir%\Setup\Scripts\dotNetFx45_Full_x86_x64.exe /q /norestart
START /WAIT %windir%\Setup\Scripts\dotNetFx45LP_Full_x86_x64pl.exe /q /norestart
START /WAIT %windir%\Setup\Scripts\NDP45-KB2737083-x64.exe /q /norestart
START /WAIT %windir%\Setup\Scripts\NDP45-KB2742613-x64.exe /q /norestart
START /WAIT %windir%\Setup\Scripts\NDP45-KB2750147-x64.exe /q /norestart
START /WAIT %windir%\Setup\Scripts\NDP45-KB2789648-x64.exe /q /norestart
START /WAIT %windir%\Setup\Scripts\msxml4-KB2758694-enu.exe /q /norestart
START /WAIT %windir%\Setup\Scripts\rvkroots.exe /q:a /r:n
START /WAIT %windir%\Setup\Scripts\Silverlight_x64.exe /q /noupdate
START /WAIT %windir%\Setup\Scripts\Windows-KB890830-x64-V4.17.exe /quiet
START /WAIT %windir%\Setup\Scripts\Reapers.Adobe.Flash.Player.ActiveX.11.6.602.168.exe
START /WAIT %windir%\Setup\Scripts\Reapers.Adobe.Flash.Player.Plugin.11.6.602.168.exe
START /WAIT %windir%\Setup\Scripts\Reapers.Adobe.Shockwave.Player.12.0.0.112.exe
START /WAIT %windir%\Setup\Scripts\Reapers.Java.Runtime.AIO.7.0.130.20.x64.exe
START /WAIT %windir%\Setup\Scripts\DirectX.exe
exit
Scripts folder containing silent installers and script cmd setupcomplete and put the system image mounted in the Windows \ Setup.
Edit for your needs.
Thanks for your input.
I didn't really get this.
Your suggestion is to integrate the Setup files to the .wim with the AIO Integrator Files Tab and then make it run the script (with modifications) you provided to install?
Edit: I googled the Setupcomplete thing and it looks very promising.
My question remains: i integrate the files with the files tab in the All in One integrator, or is it possible to edit the image manually when its mounted?
Edited by HC_TM
You can use a third-party tool like this one (simple and intuitive) to only mount the .wim and copy the ''WinToolkit_App'' folder to it. Of course, that is after everything is completed in WinToolkit.
btw, I wasn't aware that when deploying over the network, only the contents of the .wim file were discoverable by windows installation process / WinToolkit's Runonce process.
Edited by RicaNeaga
