[Solved] NSIS Error-Box in installation process
Hi Lego,
there is a problem in the Windows installation process:
if the patches KB2830477 and KB2857650 are integrated as update.
WTK moves KB2857650 to the prerequisites (is for RDP 8.x), KB2830477 stays in the normal updates.
They should be moved to the silent installers; please keep in mind my bug report.
Without this two patches under updates no issue!
BTW, mooms delivers the two patches extra as not integratable ;)
Thiersee
