Known Issues
The latest build can be downloaded from here. Here are some known issues:
  • All-In-One Integrator > Preset Manager [FIXED v1.4.38.1]
When you open AIO Integrator and untick the Show preset manager next time. It still shows.
  • All-In-One Integrator > Updates/Sorting [FIXED v1.4.38.2]
If you add updates to AlO-Integrator and then moved the items around. It affected their integration status.
  • All-In-One Integrator > Windows6.1-KB943790-x64 [FIXED v1.4.38.3]
It reports an error log has been updated due to a small error. It doesn't actually affect the integration at all so no need to worry.
Digital River seems to be no longer providing ISOs for Windows 7 SP1.
This has happened temporarily before. Hopefully they will resume the downloads.
