This is still a problem for me. There are too many files in the folders compared to what's shown on Downloaded tab. That holds true for all lists.
Here's how it looks the Office updates
The Check All thing seems to be fixed.
The updates sorting is still a problem for me. There are too many files in the folders even if the program shows exactly the same number of downloaded updates as the WHDownloader.
So the lists used are correct but the program don't filter out the old/superseded updates to move them to the apropriate folder.
This happens for all the lists.
Also the Office updates are still in some zip kind of exe format (part of them, not all). This is not happening in WHDownloader.
