Silent install wont start after W7x64 installed
Hi all !
I have successfully used Wintoolkit several times before, its a great program, but now i stucked a bit. :S
Please help me, if you have a minute  :) I'm sure its only a minute for You guys  :P
I want to install the dotnet 4.5 updates silently. Every settings, and modifications are fine, but the silent install window (after windows installation) never comes up. The settings.ini for these Silent installs / updates:
#Silent Installs
452intl_Slim::/ail [/sfxlang:1038];NO;81,06 MB;C:\w72\452intl_Slim.exe;Always Installed
NDP45-KB2979578-v2-x64::/q;NO;1,74 MB;C:\w72\updates\NDP45-KB2979578-v2-x64.exe;Always Installed
NDP45-KB2972216-x64::/q;NO;10,90 MB;C:\w72\updates\NDP45-KB2972216-x64.exe;Always Installed
NDP45-KB2972107-x64::/q;NO;3,30 MB;C:\w72\updates\NDP45-KB2972107-x64.exe;Always Installed
NDP45-KB2931368-x64::/q;NO;1,25 MB;C:\w72\updates\NDP45-KB2931368-x64.exe;Always Installed
NDP45-KB2894854-v2-x64::/q;NO;10,91 MB;C:\w72\updates\NDP45-KB2894854-v2-x64.exe;Always Installed
NDP45-KB2901126-x64::/q;NO;8,24 MB;C:\w72\updates\NDP45-KB2901126-x64.exe;Always Installed
NDP45-KB2898869-x64::/q;NO;26,05 MB;C:\w72\updates\NDP45-KB2898869-x64.exe;Always Installed
And the directory tree on the pendrive is:
boot
efi
sources
support
upgrade
WinToolkit_apps
452intl_Slim\452intl_Slim.exe
NDP45-KB2979578-v2-x64\NDP45-KB2979578-v2-x64.exe
NDP45-KB2972216-x64\NDP45-KB2972216-x64.exe
NDP45-KB2972107-x64\NDP45-KB2972107-x64.exe
NDP45-KB2931368-x64\NDP45-KB2931368-x64.exe
NDP45-KB2894854-v2-x64\updates\NDP45-KB2894854-v2-x64.exe
NDP45-KB2901126-x64\NDP45-KB2901126-x64.exe
NDP45-KB2898869-x64\NDP45-KB2898869-x64.exe
I attached the runonce log file. http://www.pigikft.hu/WinToolkit_RunOnce_Log.log
Any ideas ?
Cheers !
Ok, i just testing it right now ^^
Thanks a lot ! I'll reply soon! (but i don't understand what about the other .exes, maybe beacuse they are just updates for dotNet 4.5 ?!)
  • 11 months later...
