Hey guys,
I noticed the new option to alter the install.wim date, but it does not work for me.
I have finished intergrating everything all done, and works.
Now when i make the iso i enable the option to set date, only option i have is custom date.
What for me is date i run the app itself.
Now modify install.wim is disabled and when i install windows 7 the date is still 2010.
Any clue how i can fix this ? using version 1.5.3 downloaded yesterday and had same problems before this never got it working.
Though hopefully somebody can help me with this, as i often get questions as to when i updated the iso's last time.
Is there a reason in doing this ?
Cause if it does not modify the install.wim, yet i have to set a custom date, that tells me its not setting it to the date of the install.wim.. i just get a bit confused.
