March 24, 201511 yr I used a windows 7 sp1 image and integrated all missing updates, IE11, NetFramework4.5.2 AddOn, various drivers, MaliciousSoftwareRemovalTool as silent install, several Programs as silent Install: firefox, office, skype... Installing from a USB stick. When the installation is done and the last silent install finishes, i am left with a blanc screen. I can use ctrl, alt, del to open up task manager, then log off and immediatly log on again and then i get everything there should be. Is this a known issue? is there a work around? Kind regards, and thanks for this great tool.
March 24, 201511 yr Might be a driver issue, boot into save-mode with network, see if it loads properly, if it does install the correct video drivers, Had this issue on a windows 8.1 system even though it was from a original non upgraded cd. If thats not the case, then you might have integrated a update that messes it all up.
March 24, 201511 yr Author So far I have these observations: if I integrate no silent installs it works properly.if I do not integrate the netframe4.5.2 addon it works fine even with silent installsif I integrate netframe addon and silent installs i get a blanc screen at the end (to clarify: i get fullscreen blue windows background and i can see the mouse pointer) the installation itself does not seem to be messed up. everything is working after i open the task manager, log off and then log on again.
March 24, 201511 yr That is quite odd, though i do not use silent installs, as i use pxe,Could i recommend trying simplix pack ? then add netframework etc onto that ?
March 25, 201511 yr Author Hm, I will test if i get the same problem if I leave out the updates and only add netframework and then silent installs. I guess this will help to narrow down the problem some more. If it is indeed the updates that cause the problem I will try simplix pack. Thanks for pointing it out.
March 25, 201511 yr Author I want to boot from USB and then leave the PC alone and have all programs and updates installed unattended.
June 29, 201510 yr I have the same problem, with new and old win toolkits, it always worked but all of a sudden left with black scree, if I move the mouse it move and dissapears...
