ERROR: please check your internet connection
6 minutes ago, Jan Krohn said:
Hi,
This error means that the download tool can't connect to microsoft.com. This is your local system issue. Please have a look at the FAQ, where there's a non-exhaustive list of possible root causes for this issue.
Best wishes,
Jan
FAQ link pls
11 hours ago, Lucky41 said:
I've also the same issue. All Microsoft pages are available. I'm not understand the error message.
Any insights from the FAQ?
A: This is your local connection issue, and can have a number of root causes:
  • You have modified your HOSTS file. Please remove the following two lines.
    0.0.0.0 aa.online-metrix.net
    0.0.0.0 c.bing.com
  • You have installed software that prevents scripts from modifying secure websites, such as certain adblockers, firewalls or similar security related software.
  • You have disabled TLS 1.2 in your internet settings. You can enable it again in the control panel in the Internet Options category.
  • In rare cases, starting the tool as administrator can resolve the issue.
  • In rare cases, installing the latest Windows updates, or updating Internet Explorer or the .NET framework to the latest version can resolve the issue.
i had the same problem but i solved this by going to control panel / region/ then  change format and locations to USA.
my set up before was  Saudi Arabia .
now i am using windows 8.1 enterprise evaluations .
in windows 7 go to control panel / language and region / then  change format and locations to USA.
note : i set up back to Saudi Arabia but the problem back again and then set up to USA and  the download appears to be downloaded ok i downloaded some of windows and office and that was perfect .
  • 4 weeks later...
