Posted January 9, 20205 yr Summary: FormatFactory is a multifunctional media converter. Provides functions below: All to MP4/3GP/MPG/AVI/WMV/FLV/SWF. All to MP3//WMA/MMF/AMR/OGG/M4A/WAV. All to JPG/BMP/PNG/TIF/ICO... Rip DVD to video file , Rip Music CD to audio file. MP4 files support iPod/iPhone/PSP/BlackBerry format. Source files support RMVB. Support converting all popular video,audio,picture formats to others. Repair damaged video and audio file. Reducing Multimedia file size. Support iphone,ipod multimedia file formats. Picture converting supports Zoom,Rotate/Flip,tags. Functions: All to MP4/3GP/MPG/AVI/WMV/FLV/SWF。 All to MP3/WMA/AMR/OGG/AAC/WAV。 All to JPG/BMP/PNG/TIF/ICO/GIF/TGA。 Rip DVD to video file,Rip Music CD to audio file. MP4 files support iPod/iPhone/PSP/BlackBerry format. Supports RMVB,Watermark,AV Mux. Features: Support converting all popular video,audio,picture formats to others. Repair damaged video and audio file. Reducing Multimedia file size. Support iphone,ipod multimedia file formats. Picture converting supports Zoom,Rotate/Flip,tags. DVD Ripper. Supports 62 languages Password: damas Silent installation Quote https://www.mediafire.com/file/584qh8e1kk4h509/Format+Factory+5.20.0.0+x64+Silent+Install.7z/file https://www.mirrored.to/files/STBCNYCN/Format_Factory_5.20.0.0_x64_Silent_Install.7z_links G Edited November 9, 2024Nov 9 by 大†Shinegumi†大
May 22, 20213 yr Author V5.7.5 2021.05.20 1 Added adjustable number of task threads 2 Added support for older Win7 without OpenGL 3 PDF password supports batch input 4 Fixed bug that saving of window size and position 5 Fixed a bug of Video Joiner&Mux that could not be flipped and rotated V5.7.1 2021.04.02 1 Added Text->Wav 2 Added Docx->PDF 3 Improved PDF to Docx function 4 Fixed a bug when converting large video files 5 Added key frame interval option in video output setting 6 Fixed the bug of custom profile V5.6.5 2021.02.10 1 Update MP3 Encoder Lame3.99 to 3.100 2 Fixed the bug for adding water mark when hardware acceleration 3 Fixed the bug for Format Player 4 Added color filter in video output settging V5.6.0 2021.01.10 1 Added function to add video and audio cover 2 Improved subtitle font color configuration 3 Added file sorting function 4 Improved keep aspect cropping in video option 5 Added sample format option in audio output setting 6 Added lossless words before audio lossless configuration V5.5.0 2020.11.19 1 Improved "Delogo" to support to remove multiple areas watermark. 2 Improved Video/Audio Output Setting GUI 3 Added "Keep All Source Streams" Audio&Subtitle option in output setting 4 Fixed bugs of Fast Clip 5 Update the nvidia Video Codec SDK to ver 10.0.26 V5.4.5 2020.9.1 1 Fixed bugs of ncm decoder 2 Fixed bugs of the time format in the French system 3 Added GPU priority in output setting 4 Added "Add Folder" button in file select UI V5.4.0 2020.8.5 1 Added ncm and KUX decoder 2 Fixed a bug of MIDI decoder 3 Improved Video Clip GUI 4 Improved Video Joiner & Mux V5.3.0 2020.6.16 1 Added support for dividing by file size 2 Fixed the bug that UTF8 file name causes conversion failure 3 Fixed the bug of Clip UI 4 Fixed the bug of losting audio meta data V5.2.0 2020.5.26 1 Added AV1 encoder support for MP4 and MKV 2 Added AV stream splitter 3 Added music library support for Video Joiner & Mux 4 Fixed the bug of volume control 5 Redesigned the file select dialog UI V5.1.0 2020.3.20 1 Added support for AMD graphics card 2 Added picture files to PDF 3 Added PDF Encrypt,Decrypt,Compress 4 Added audio files to DTS 5 Fixed the bug of Expand(black&white) in aspect ratio 6 Added loop option in Mux 7 Updated UI Icons to High DPI pixmap V5.0.0 2020.2.10 1 Upgraded to 64-bit, no longer supports 32-bit Windows 2 reserved cover picture when convert to MP3, FLAC, M4A 3 Added video output setting metadata title, author, and comment 4 fixed the bug of GPU tester V4.9.5 2019.11.18 1 Adding aspect ratio options in video clip 2 Adding fade in,fade out in audio output setting 3 Support for adding blank intervals in audio joiner 4 Fixed the bugs of DVDRip libfaac.dll missing V4.9.0 2019.9.28 1 Added "PDF Joiner" 2 Added "Video Downloader" 3 Added "Fast Clip" 4 Added "Divided Into" 5 Added "Fade In" and "Fade Out" in "Output Setting" 6 Fixed the bug of cropping the vertical video file 7 Fixed the bug of "Audio Codec Not Supported" 8 Fixed the Compatibility problems in Win7 9 Fixed the bug of joining the horizontal and vertical video files in "Video joiner" V4.8.0 2019.7.4 1 Added "Screen Record" 2 Added "PDF to Pic" 3 Added support for Intel QSV H264,H265 hardware acceleration 4 Fixed bugs of GPU conflict in multi-tasks 5 Adjust "Optimum quality and size" profile to fit 4K video 6 Fixed bugs of MKV subtitle 7 Fixed 'charmap' codec error for "PDF to XXX" V4.7.0 2019.5.30 1 Added "PDF to TXT" 2 Added "PDF to Doc" 3 Added "PDF to Excel" 4 Added AMR decoder "SilkV3" 5 Fixed bugs of "All to MPG" V4.6.1 2019.4.26 1 Fixed the crash bug of HEIC decoder 2 Added profile "Optimum quality and size" 3 Adjusted some profiles of MP4 and MKV 4 Fixed bugs of using "GPU" in multi-tasks 5 Added GPU switch option in video output setting 6 Added Shortcuts for "Deloge" and "Crop" V4.5.5 2018.12.25 1 Added video "Delogo" in Clip 2 Added video "Speed" option in Output Setting V4.5 2018.11.27 1 Added "FFZip" module to the "Document" 2 Added the Archive compression and decompression function to the right-click menu. 3 Added Language "Tibetan"
May 6, 20223 yr Author Qué hay de nuevo: Changes in Format Factory 5.11.0.0: Added “Split Music” to separate voice and music Integrate AC3,AAC,MMF,DTS in one function Fixed bugs of Modules Downloader Fixed FormatPlayer’s drag-in crash Fixed an issue with aspect distortion in video joiner
July 16, 20222 yr Author Changes in Format Factory 5.12.0.0: Updated CD repository to point to gnudb.gnudb.org Adjusted audio and video bitrate of profile Fixed bug with custom profile Changes in Format Factory 5.11.0.0: Added “Split Music” to separate voice and music Integrate AC3,AAC,MMF,DTS in one function Fixed bugs of Modules Downloader Fixed FormatPlayer’s drag-in crash Fixed an issue with aspect distortion in video joiner Changes in Format Factory 5.10.0.0: Added the cover save function of audio files Improved QSV file decoding Fixed the bug of keeping the source subtitle stream in MKV Streamlined output setting profiles Added range selection function to AV splitter Added FormatPlayer decoding option Changes in Format Factory 5.9.0.0: Update encoder FFMPEG to latest version 4.4 Added QSV vp9 HA encoder Added Video&Photo optimize feature Added “Add Music” in video conversion Added feature icon in output setting Added step backward&forward button in FormatPlayer Added video anti-shake,noise reduction,reverse play filter Added audio echo, noise reduction, reverse play filter Added new resource in music library Added support for duration in blur and Delogo Added automatic compression after PDF merge Fixed the bug of text to Wav Fixed the bug of saving window size after resolution switch Changes in Format Factory 5.8.1.0: Added support for pictures in Video Joiner & Mux Added picture sequence support in Video conversion Added a button to delete the source file after successfully converted Added Export Frame function Fixed the Win11 incompatibility problem Fixed the bug of FormatPlayer Fixed the bug , no sound in Mux Fixed the bug , when adding directories Changes in Format Factory 5.7.5.0: Added adjustable number of task threads Added support for older Win7 without OpenGL PDF password supports batch input Fixed bug that saving of window size and position Fixed a bug of Video Joiner&Mux that could not be flipped and rotated Changes in Format Factory 5.7.1.0: Added Text->Wav Added Docx->PDF Improved PDF to Docx function Fixed a bug when converting large video files Added key frame interval option in video output setting Fixed the bug of custom profile
August 5, 20222 yr Author V5.12.0 2022.07.14 1 Updated CD repository to point to gnudb.gnudb.org 2 Adjusted audio and video bitrate of profile 3 Fixed bug with custom profile
December 1, 20222 yr Author Changes in Format Factory 5.13.0.0: Updated Exiv2 picture information library Updated ffmpeg5.1 stable version Changed the naming rules in video joiner & Mux Fixed the bug of add images in video joiner & Mux Added av1_nvenc,h264_mf,h265_mf Hardware encoder Optimized the encoding parameter of h26X_nvenc h26X_qsv h26X_amf Added constant quantization parameter(cq) in h26X_nvenc Optimized the resolution of Low&Medium quality and size
April 13, 20232 yr Author V5.14.0.1 2023.04.08 1 Updated ffmpeg 6.0 contains many new decoders 2 Added av1_qsv av1_amf Hardware encoder 3 Fixed bugs of player 4 Fixed bugs of external subtitles file 5 Adjusted naming rules for file dividing
August 10, 20231 yr Author V5.15.0 2023.7.21 1 Fixed bugs of video clip 2 Adjusted the default subtitle border size 3 Added more output directory options 4 Fixed a bug of installer
November 4, 20231 yr Author Changes in Format Factory 5.16.0.0: Added support for Multi-Profiles output setting Fixed the bug of volume adjustment Fixed the profiles of AC3 output setting
January 30, 20241 yr Author V5.17.0 2024.1.5 1 Added showing CPU&GPU usage the task progress bar 2 Fixed a bug in the installation package. 3 Fixed some dependencies in video configuration parameters
November 9, 2024Nov 9 Author Changes in Format Factory 5.20.0.0: Uрdаtе thе еnсоdеr соrе tо thе lаtеѕt ffmреg 7.1 Uрdаtе thе thіrd-раrtу dереndеnсу lіbrаrу tо thе lаtеѕt fоntсоnfіg 2.15,frееtуре-2.13,brоtlі-1.1.0,lіbvрl-2.13 Uрdаtе thе lаtеѕt hаrdwаrе ассеlеrаtіоn ѕuрроrt fоr ѕоmе еnсоdеrѕ Аdd nеw еnсоdеr VVС(Н266) tо МР4 аnd МКV Аdd НЕVС(Н265),VР9,АV1 еnсоdеrѕ tо FLV
