Hi all,
i have a receiver Astra 8900 and wanna to manually add a code of encrypted channel to be opened there
I know that i can enter the code area using this sequence
Menu->STB Setting->press 1234 and the page of all types of code come up so that i can enter the code of channel but the problem is the code i get it about 32 alphanumeric but the code area is only take 16 alphanumeric and this is my problem .
i.e. HOW i can enter the code ? and which type of code i can enter it in?
This is the an example of code that i wanna to add
provider :000000
et index :00
5A7131FC68B99FC0494FB64E149721CC
The choices of codes are:
Viaccess
Irdeto/BetaCrypt
Nagravision
Seca
Conax
Biss
Cryptoworks
Hope that it is clear
NOTE: I don't wanna to make update of software of my receiver. I'm asking about manually enter the code of new channel.
The manual don't mention any thing about this part. for the web i post the request in some forums and still waiting for any reply
the forums that i post in them some are satellite forums and some are general forums but till now i don't get any answer
