October 1, 20214 yr KMPlayer (Korean Media Player) is a versatile multimedia player which can cover a various different types of contained formats. Without any separate Codec, you are able to play any media files because KMPlayer has its’ own internal Codec. Supported codecs are separated by internal and external. For the sound Codec, KMP supports RTS, MPEG1, MPEG2, AAC, WMA7, WMA8, OGG, etc. In addition it supports matrix normalizer function when internal sound Codec is being used. Internal Codec gets processed inside of KMPlayer so it’s faster and safer. Also supports all the Codec from ffdshow and MPEG1/2 additionally. KMPlayer supports high resolution movie playback. That allows you to watch movies in superb quality with support for 3D, 4K, 8K, UHD and 60FPS. Moreover, KMP allows to capture audio and video or screen capture is possible. You can save it in the format you want. The codecs come bundles with the software, hence you can watch movies quickly and efficiently. KMPlayer also provides full control over DVD selection, Movie menus, audio menus, subtitle menus, brightness, contrast and more, to suit user needs. Key features High quality video: You can watch high quality video such as 4K, 8K, UHD, 60FPS more vividly than any other player. - It is possible to rotate the screen and play the high quality video using the more powerful Video Renderer. - The latest high-quality video codecs such as HEVC (h.265), h.264, VP9 also use the hardware acceleration function, so CPU usage rate is very low, so you can enjoy high quality video even in low-end PC or multitasking environment. - Support almost all video formats. - Supports subtitles and Blu-ray image subtitles in various file formats (PGS subtitles, etc.). - Supports Blu-ray Disc and DVD. - YouTube download function: You can enter the YouTube URL and play and download right from KMPlayer. 'PC (64bit)'! - GIF capture function: It is possible to capture the moving image by moving image (GIF format). - Support for various languages in 42 countries System Requirements Recommended Windows 10 64-bit, Direct X 9 or higher, 150Mb of installation space Minimum Windows Vista 64-bit, Direct X 9 or later, 150Mb of installation space Benefits Of KMPlayer 2023 KMPlayer download is also the only media player that will be a 3D viewing alternative in 2023, which reveals that it has noticed an emerging pattern. KMPlayer has also come to be the de facto media player for webcasting globe championship video game events, which has actually made it a really passionate particular niche adhering to. Beyond that target audience, it attract any type of user thinking about an extremely personalized video clip experience. By download NEW KMPlayer 2023 FREE! the music performance is rather doing not have; so if you’re looking for a media player that also operates as a songs monitoring tool, this might not be the most effective option. With a lot of personalization options for video clip playback, some intro-level individuals could get slowed down in all the menus and preferences. Other users who want a stripped-down video player may obtain annoyed with all of the material exploration elements, as KMPlayer MultiMedia Player is constantly raising advertisements as well as links for third-party content. KMPlayer 4.2.3.6 x86 /x64 Silent Quote https://www.mediafire.com/file/m3eao9iun1tb2oh/KMPlayer_4.2.3.6_Silent_Install.7z/file https://uploadrar.com/fibci8jz9bu8 KMPlayer 2023.11.24.16 x64 Silent Quote https://www.mediafire.com/file/zr2jp7r5i0a1q1v/KMPlayer_2023.11.24.16_x64_Silent_Install.7z/file https://uploadrar.com/y13qct1npak3 الكاتب Edited November 26, 20232 yr by 大†Shinegumi†大
November 26, 20214 yr Author Changes in KMPlayer 4.2.2.59: Improved the method of applying the button image in the main player background. Improved UI/UX to increase user convenience. Changes in KMPlayer 4.2.2.58: Changed default renderer on Windows11 OS. Improved UI/UX to increase user convenience. Changes in KMPlayer 4.2.2.57: IImproved the volume control function when playing the wing window video. Changed the background image link on the main screen. Improved UI/UX to increase user convenience. Changes in KMPlayer 2021.11.25.32 x64: Fixed intermittent interruption during video playback Fixed URL Download Engine Change video playback speed default setting Changes in KMPlayer 2021.10.26.03 x64: Fixed the problem that some formats (mp4, mkw, etc.) cannot be played. Fixed an issue where some quick buttons were not activated when using a dual monitor URL download engine update Other bug fixes and stabilization
December 16, 20214 yr Author Changes in KMPlayer 4.2.2.60: Improved UI/UX to increase user convenience. Improved the volume control function when playing the wing window video.
December 23, 20214 yr Author Changes in KMPlayer 2021.12.23.19 x64: URL download engine update Other bug fixes and stabilization
January 30, 20224 yr Author Changes in KMPlayer 4.2.2.61: Improved the wing window browser UI. Improved UI/UX to increase user convenience. Upgrade the YouTube download function. Changes in KMPlayer 2022.1.27.13 x64: Global language editing. Added OSD font size Added button tooltips. Fixed a problem that the size of the whole window does not fit. URL download engine update
March 26, 20224 yr Author Changes in KMPlayer 4.2.2.63: Improved video thumbnail extraction function Improved the link to the installation file on the homepage Improved UI/UX to increase user convenience. Changes in KMPlayer 2022.3.25.17 x64: URL download engine update Other bug fixes and stabilization
May 20, 20224 yr Author Changes in KMPlayer 4.2.2.65: Fixing Invalid Character Error on partial subtitles file. Fixing Keyboard shortcuts not working on partial file. Improve User Experience and User Interface for the convenience.
May 28, 20224 yr Author Changes in KMPlayer 4.2.2.65: Fixing Invalid Character Error on partial subtitles file. Fixing Keyboard shortcuts not working on partial file. Improve User Experience and User Interface for the convenience. Changes in KMPlayer 2022.5.26.12 x64: Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
June 17, 20223 yr Author Changes in KMPlayer 4.2.2.66: Improve Wing Browser Feature Improve function of Thumbnail Image Extraction Improve User Experience and User Interface for the convenience. Changes in KMPlayer 2022.5.26.12 x64: Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
July 25, 20223 yr Author Changes in KMPlayer 4.2.2.67: Improvements to the voice effect of the default voice filter Improvement of automatic deletion problem when bookmark is selected Improve Us Changes in KMPlayer 2022.6.30.23 (x64): Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
November 26, 20223 yr Author Changes in KMPlayer 4.2.2.71: Fixed video thumbnail extraction bug Fixed hardware decoder setting bug Changed the initial menu settings at first installation Changes in KMPlayer 2022.11.25.17 (x64): Increase your net worth, KMPlex! You can get Free Coins! https://www.kmplayer.com/kmplex URL download engine update Other bug fixes and stabilization
January 29, 20233 yr Author Changes in KMPlayer 4.2.2.73: Fixed the problem that Automatic correction function is not set when changing performance settings. Changed options when calling statistics log. Improve User Experience and User Interface for the convenience Changes in KMPlayer 2023.1.26.12 (x64): Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
February 9, 20233 yr Author Changes in KMPlayer 4.2.2.73: Fixed the problem that Automatic correction function is not set when changing performance settings. Changed options when calling statistics log. Improve User Experience and User Interface for the convenience Changes in KMPlayer 2023.2.9.11 (x64): Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
February 25, 20233 yr Author Changes in KMPlayer 4.2.2.74: Fixed video thumbnail extraction Bug Fixed hardware decoder setting bug Improve User Experience and User Interface for the convenience Changes in KMPlayer 2023.2.24.16 (x64): Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
April 19, 20233 yr Author Changes in KMPlayer 4.2.2.76: Fixed side screen black screen bug when playing video after audio playback Fixed bug where image processing filter priority was not set correctly Improve User Experience and User Interface for the convenience Changes in KMPlayer 2023.3.29.22 (x64): Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
May 16, 20233 yr Author Changes in KMPlayer 4.2.2.77: — Changes in KMPlayer 2023.4.26.13 (x64): Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
August 17, 20232 yr Author Changes in KMPlayer 4.2.3.1: Improvement of URL download function Improved URL playback function Changes in KMPlayer 2023.7.26.17 (x64): Increase your net worth, KMPlex! You can get Free Coins! URL download engine update Other bug fixes and stabilization
November 26, 20232 yr Author Changes in KMPlayer 4.2.3.6: Improvement of URL download function Improved URL playback function Changes in KMPlayer 2023.11.24.16 (x64): Increase your net worth, KMPlex! You can get Free Coins! URL download engine update AV1 Codec Support and engine update Other bug fixes and stabilization
