(Error) Sorry, but we're having trouble signing you in.
URL: https://login.microsoftonline.com/common/oauth2/authorize?client_id=e5646d90-d003-4db5-9698-d6d2b03d88c5&response_mode=form_post&response_type=code id_token&scope=openid profile&state=OpenIdConnect.AuthenticationProperties%3D1TMHURCHwy8uoERq-KkmP6akctttXOF_O7AHoUtASLSC4MF-A1-g0N-7H5euVU-YakB9hEs1i-TTGI2H3y8m8pM2iNa8geKl6b4ugdVjBjiXRYrWsyt4LOv2WuJzhtLmbnsujc_MeI9UkBB5fQkMWEZCr7oYXr5ZhD3c7VsujjSclj8Vz76OP5MeTVlwz0gpBauSl5ITaQVe5h6ZWl74AJSBIbeGjrGgQuv3MsV365hNwXlKcG_sRC8XFQCk04P-dxqnUlMWGlu4y3hEnAappbYbtXY&nonce=637842547956098627.NTMyOWJiZjAtZWFhNi00ZmVmLTk5YWQtM2JiNzNjOGYyYzM4ODAxMTQ0NTAtZjkwZC00M2I4LTljNGEtZTZhM2IxYjlhOGM2&msafed=0&post_logout_redirect_uri=https%3A%2F%2Fwww.microsoft.com%2Fen-us%2Fsoftware-download%2Fwindows10ISO&redirect_uri=https%3A%2F%2Fwww.microsoft.com%2Fen-us%2Fsilentauth%3Fsilentauth%3Daad%26f%3D255%26MSPPError%3D-2147217396&prompt=none&x-client-SKU=ID_NET461&x-client-ver=6.8.0.0&iframe-request-id=55ef9c6d-8da1-4c64-a1e2-c4faa9aaa800
Document: <body class="cb" style="font-size: smaller; -ms-overflow-style: none;" data-bind="defineGlobals: ServerData, bodyCssClass">
    <script type="text/javascript">//<![CDATA[
!function(){var e=window,o=e.document,i=e.$Config||{};if(e.self===e.top){o&&o.body&&(o.body.style.display="block")}else if(!i.allowFrame){var s=e.self.location.href,l=s.indexOf("#"),n=-1!==l,t=s.indexOf("?"),f=n?l:s.length,d=-1===t||n&&t>l?"?":"&";s=s.substr(0,f)+d+"iframe-request-id="+i.sessionId+s.substr(f),e.top.location=s}}();
//]]></script>
//<![CDATA[
(function () {
var $Prefetch={"rfPre":true,"delay":5000,"maxHistory":4,"maxAge":43200,"ageRes":1440,"name":"clrc","fetch":[{"path":"https://aadcdn.msauth.net/ests/2.1/content/cdnbundles/converged.v2.login.min_zmhwgv_kbcs-aml46kcgfg2.css","hash":"EaDIOExo","co":true},{"path":"https://aadcdn.msauth.net/ests/2.1/content/cdnbundles/ux.converged.error.strings-en.min_5hboq7_nb7svrjtnu29bda2.js","hash":"aF2T/udw","co":true}],"mode":5};
!function(e,t,n){function r(e){x.appendLog&&x.appendLog("Client Prefetch: "+e)}function i(){try{for(var e=t.cookie.split(";"),r=0;r<e.length;r++){var i=e[r];if(i){var o=i.indexOf("=");if(-1!==o){if(i.substr(0,o).trim()===n.name){var u=i.substr(o+1);return JSON.parse(c(u))}}}}}catch(e){}return{}}function o(e,t,n){return e.replace(t,n)}function c(e){return e=o(e,/%5c/g,"\\"),e=o(e,/%3e/g,">"),e=o(e,/%3d/g,"="),e=o(e,/%3c/g,"<"),e=o(e,/%3b/g,";"),e=o(e,/%3a/g,":"),e=o(e,/%2c/g,","),e=o(e,/%27/g,"'"),
e=o(e,/%22/g,'"'),e=o(e,/%20/g," "),e=o(e,/%25/g,"%")}function u(e){return e=o(e,/%/g,"%25"),e=o(e,/ /g,"%20"),e=o(e,/"/g,"%22"),e=o(e,/'/g,"%27"),e=o(e,/,/g,"%2c"),e=o(e,/:/g,"%3a"),e=o(e,/;/g,"%3b"),e=o(e,/</g,"%3c"),e=o(e,/=/g,"%3d"),e=o(e,/>/g,"%3e"),e=o(e,/\\/g,"%5c")}function f(e){var r=new Date;r.setTime(r.getTime()+C*H),t.cookie=n.name+"="+u(JSON.stringify(e))+";expires="+r.toUTCString()+";path=/; Secure; SameSite=None"}function a(e,t){if(e){if(e.indexOf){return e.indexOf(t)}
for(var n=0;n<e.length;n++){if(e[n]===t){return n}}}return-1}function h(e,t){return-1!==a(e,t)}function g(e,t){var n=a(e,t);return-1!==n&&(e.splice(n,1),!0)}function l(e,t){for(var n in e){if(e.hasOwnProperty(n)&&!t(n,e[n])){break}}}function s(){var e=(new Date).getTime(),t=D*H;return P.getTime()>e?Math.round(e/t):Math.round((e-P.getTime())/t)}function d(e,t){var n=!1;if(t&&t.length>0){n=!0;for(var r=0;r<t.length;r++){delete e[t[r]]}}return n}function p(e){var t=s()-C,n=t+2*C,r=null,i=0,o=[]
;return l(e,function(c){return c<t||c>n?o.push(c):(0===e[c].length?o.push(c):(null===r||c<r)&&(r=c),i++),!0}),null!==r&&i>k&&o.push(r),d(e,o)}function v(e,t,n){r("Fetched: "+e+" Hash: "+t+" isRefresh: "+n);var o=i(),c=s(),u=!1,a=!1;if(l(o,function(e,n){return!h(n,t)||(e!==c?g(o[e],t)&&(a=!0):u=!0,!1)}),!u){var d=o[c]||[];d.push(t),o[c]=d,a=!0}a|=p(o),a&&f(o),b()}function m(t,n,i,o){var c={"method":"GET"};i&&(c.mode="cors"),e.fetch(t,c).then(function(e){
200===e.status?v(t,n,o):(r("Unexpected response - "+e.status),b())}).then(null,function(e){r("Failed - "+e),b()})}function T(){if(e.XMLHttpRequest&&!J){return new XMLHttpRequest}if(e.ActiveXObject){try{return new ActiveXObject("Msxml2.XMLHTTP")}catch(e){}try{return new ActiveXObject("Microsoft.XMLHttp")}catch(e){}}return null}function w(e,t,n,i,o){r("Fetching - "+t),e.onload=function(){v(t,n,o)},e.onerror=function(){r("XHR failed!"),b()},e.ontimeout=function(){r("XHR timed out!"),b()};try{e.open("GET",t),
e.withCredentials=i&&!N,e.send()}catch(r){N?setTimeout(function(){v(t,n,o)},0):(N=!0,w(e,t,n,!1,o))}}function O(t,n,i,o){if(e.fetch){return void m(t,n,i,o)}var c=T();if(null!==c){return void w(c,t,n,i,o)}r("Unable to identify a transport option!")}function b(){var e=n.fetch;if(X<e.length&&e[X]){var t=e[X];O(t.path,t.hash,t.co||!1,t.rf||!1),X++}}function y(e){if(e){try{var n=t.createElement("link");n.rel="prefetch",n.href=e,t.head.appendChild(n)}catch(e){}}}function M(){r("Starting"),b(),b()}function S(){
for(var t=e.$Config||e.ServerData||{},r=n.fetch,i=n.mode||-1,o=-1,c=0;c<r.length;c++){0!==o&&i>=3&&(o=r[c].rf?1:0),R&&!J&&y(r[c].path||{})}t.prefetchPltMode=o}if(n&&n.fetch&&0!==n.fetch.length){var x=e.$Debug||{},X=0,H=6e4,P=new Date(2019),k=n.maxHistory||4,C=n.maxAge||20160,D=n.ageRes||1440,L=n.delay||5e3,R=n.rfPre||!1,J=void 0!==(e._phantom||e.callPhantom),N=!1;JSON&&JSON.parse&&(n.clearCookie=function(){document.cookie=n.name+"=; expires=Thu, 01 Jan 1970 00:00:01 GMT;"},e.$Do.when("doc.load",function(){
setTimeout(M,L),setTimeout(S,0)}))}}(window,document,$Prefetch);
</script>
<div><!--  -->
<form spellcheck="false" method="post" target="_top" novalidate="novalidate" autocomplete="off" data-bind="autoSubmit: forceSubmit, attr: { action: postUrl }">
    <!-- ko withProperties: { '$errorPage': $data } -->
    <div data-bind="component: { name: 'master-page',&#10;        publicMethods: masterPageMethods,&#10;        params: {&#10;            serverData: svr,&#10;            showButtons: svr.fShowButtons,&#10;            showFooterLinks: true,&#10;            handleWizardButtons: false,&#10;            useWizardBehavior: svr.fUseWizardBehavior } }"><!--  -->
<!-- ko ifnot: useLayoutTemplates --><!-- /ko -->
<!-- ko if: useLayoutTemplates -->
    <!-- ko withProperties: { '$page': $parent } -->
        <!-- ko if: isLightboxTemplate() -->
        <div id="lightboxTemplateContainer" data-bind="component: { name: 'lightbox-template', params: { serverData: svr, showHeader: $page.showHeader(), headerLogo: $page.headerLogo() } }"><!--  -->
<div id="lightboxBackgroundContainer" data-bind="component: { name: 'background-image-control',&#10;    publicMethods: $page.backgroundControlMethods,&#10;    event: { load: $page.backgroundImageControl_onLoad } }"><div class="background-image-holder" role="presentation" data-bind="css: { app: isAppBranding }, style: { background: backgroundStyle }">
    <!-- ko if: smallImageUrl --><!-- /ko -->
    <!-- ko if: backgroundImageUrl -->
    <div class="background-image ext-background-image" style='background-image: url("https://aadcdn.msauth.net/shared/1.0/content/images/backgrounds/2_bc3d32a696895f78c19df6c717586a5d.svg");' data-bind="backgroundImage: backgroundImageUrl(), externalCss: { 'background-image': true }"></div>
        <!-- ko if: useImageMask --><!-- /ko -->
    <!-- /ko -->
</div></div>
<!-- ko if: svr.iBannerEnvironment --><!-- /ko -->
<!-- ko withProperties: { '$masterPageContext': $parentContext } -->
<div class="outer" data-bind="css: { 'app': $page.backgroundLogoUrl }">
    <!-- ko if: showHeader --><!-- /ko -->
    <div class="template-section main-section">
        <div class="middle ext-middle" data-bind="css: { 'has-header': showHeader }, externalCss: { 'middle': true }">
            <div class="full-height" data-bind="component: { name: 'content-control', params: { serverData: svr, isVerticalSplitTemplate: $page.isVerticalSplitTemplate() } }"><!--  -->
<!-- ko withProperties: { '$content': $data } -->
<div class="flex-column">
    <!-- ko if: $page.paginationControlHelper.showBackgroundLogoHolder --><!-- /ko -->
    <!-- ko if: $page.paginationControlHelper.showPageLevelTitleControl --><!-- /ko -->
    <div class="win-scroll">
        <div class="sign-in-box ext-sign-in-box lightbox-bottom-margin-debug fade-in-lightbox wide" id="lightbox" data-bind="&#10;            animationEnd: $page.paginationControlHelper.animationEnd,&#10;            externalCss: { 'sign-in-box': true },&#10;            css: {&#10;                'inner':  $content.isVerticalSplitTemplate,&#10;                'vertical-split-content': $content.isVerticalSplitTemplate,&#10;                'app': $page.backgroundLogoUrl,&#10;                'wide': $page.paginationControlHelper.useWiderWidth,&#10;                'fade-in-lightbox': $page.fadeInLightBox,&#10;                'has-popup': $page.showFedCredAndNewSession &amp;&amp; ($page.showFedCredButtons() || $page.newSession()),&#10;                'transparent-lightbox': $page.backgroundControlMethods() &amp;&amp; $page.backgroundControlMethods().useTransparentLightBox,&#10;                'lightbox-bottom-margin-debug': $page.showDebugDetails }">
            <!-- ko template: { nodes: $masterPageContext.$componentTemplateNodes, data: $page } -->
        <div class="lightbox-cover" data-bind="css: { 'disable-lightbox': svr.fAllowGrayOutLightBox &amp;&amp; isRequestPending() }"></div>
        <!-- ko if: isRequestPending --><!-- /ko -->
        <!-- ko if: loadBannerLogo -->
        <div data-bind="component: { name: 'logo-control', params: { isChinaDc: svr.fIsChinaDc, bannerLogoUrl: bannerLogoUrl() } }"><!--  -->
<!-- ko if: bannerLogoUrl --><!-- /ko -->
<!-- ko if: !bannerLogoUrl && !isChinaDc -->
    <!-- ko component: 'accessible-image-control' --><!-- ko if: (isHighContrastBlackTheme || hasDarkBackground || svr.fHasBackgroundColor) && !isHighContrastWhiteTheme --><!-- /ko -->
<!-- ko if: (isHighContrastWhiteTheme || (!hasDarkBackground && !svr.fHasBackgroundColor)) && !isHighContrastBlackTheme -->
<!-- ko template: { nodes: [darkImageNode], data: $parent } --><img class="logo" role="img" alt="Microsoft" src="https://aadcdn.msauth.net/shared/1.0/content/images/microsoft_logo_ee5c8d9fb6248c938fd0dc19370e90bd.svg" data-bind="imgSrc, attr: { alt: str['MOBILE_STR_Footer_Microsoft'] }" svgsrc="https://aadcdn.msauth.net/shared/1.0/content/images/microsoft_logo_ee5c8d9fb6248c938fd0dc19370e90bd.svg" pngsrc="https://aadcdn.msauth.net/shared/1.0/content/images/microsoft_logo_ed9c9eb0dce17d752bedea6b5acda6d9.png"><!-- /ko -->
<!-- /ko --><!-- /ko -->
<!-- /ko --></div>
        <!-- /ko -->
        <div role="main" data-bind="component: { name: 'pagination-control',&#10;                publicMethods: paginationControlMethods,&#10;                params: {&#10;                    enableCssAnimation: svr.fEnableCssAnimation,&#10;                    disableAnimationIfAnimationEndUnsupported: svr.fDisableAnimationIfAnimationEndUnsupported,&#10;                    initialViewId: initialViewId },&#10;                event: {&#10;                    cancel: paginationControl_onCancel,&#10;                    load: paginationControlHelper.onLoad,&#10;                    unload: paginationControlHelper.onUnload,&#10;                    loadView: view_onLoadView,&#10;                    showView: view_onShow,&#10;                    setLightBoxFadeIn: view_onSetLightBoxFadeIn } }"><!--  -->
<div data-bind="css: { 'zero-opacity': hidePaginatedView() }">
    <!-- ko if: showIdentityBanner() && (sharedData.displayName || svr.sPOST_Username) --><!-- /ko -->
    <div class="pagination-view animate slide-in-next" data-bind="css: {&#10;        'has-identity-banner': showIdentityBanner() &amp;&amp; (sharedData.displayName || svr.sPOST_Username),&#10;        'zero-opacity': hidePaginatedView.hideSubView(),&#10;        'animate': animate(),&#10;        'slide-out-next': animate.isSlideOutNext(),&#10;        'slide-in-next': animate.isSlideInNext(),&#10;        'slide-out-back': animate.isSlideOutBack(),&#10;        'slide-in-back': animate.isSlideInBack() }">
        <!-- ko foreach: views -->
            <!-- ko if: $parent.currentViewIndex() === $index() -->
                <!-- ko template: { nodes: [$data], data: $parent } --><div data-bind="pageViewComponent: { name: 'error-view',&#10;                    params: {&#10;                        serverData: svr },&#10;                    event: {&#10;                        submitReady: $errorPage.view_onSubmitReady } }" data-wide="true" data-viewid="1"><!--  -->
<div class="row text-title" id="header" role="heading" aria-level="1" data-bind="text: unsafe_headerText">Sign in</div>
<div tabindex="-1" class="row text-body" data-bind="hasFocus: !svr.fIsOOBE">
    <p class="text-block-body no-margin-top" id="pageDescription" data-bind="text: errorDescription">Sorry, but we’re having trouble signing you in.</p>
</div>
<!-- ko if: svr.fDebugModeEnabled --><!-- /ko -->
<div class="row text-body" data-bind="text: svr.strExceptionClassName"></div>
<div class="row text-body" data-bind="text: unsafe_exceptionMessage">AADSTS50058: A silent sign-in request was sent but no user is signed in.</div>
<div class="row text-body stack-trace text-caption wrap-content" data-bind="html: stackTrace"></div>
<!-- ko if: svr.fIsOOBE --><!-- /ko -->
<!-- ko if: tenantBranding.BoilerPlateText --><!-- /ko --></div><!-- /ko -->
            <!-- /ko -->
            <!-- ko if: $parent.currentViewIndex() === $index() --><!-- /ko -->
        <!-- /ko -->
    </div>
</div></div>
        <div data-bind="component: { name: 'instrumentation-control',&#10;            publicMethods: instrumentationMethods,&#10;            params: { serverData: svr } }">
<input name="i19" type="hidden" value="" data-bind="value: timeOnPage"></div>
    <!-- /ko -->
        </div>
        <!-- ko if: $page.showFedCredAndNewSession --><!-- /ko -->
        <!-- ko if: $page.showDebugDetails -->
        <div data-bind="component: { name: 'debug-details-control',&#10;            publicMethods: $page.debugDetailsMethods,&#10;            params: {&#10;                serverData: svr,&#10;                debugDetails: $page.debugDetails,&#10;                useWiderWidth: $page.paginationControlHelper.useWiderWidth,&#10;                isDebugTracingEnabled: $page.isDebugTracingEnabled },&#10;            event: {&#10;                closeBanner: $page.closeDebugDetails_onClick,&#10;                setDebugTracing: $page.setDebugTracing_onClick } }"><!--  -->
<!-- ko if: showBanner -->
<div class="debug-details-banner table wide" id="debugDetailsBanner" data-bind="css: { 'wide': useWiderWidth }">
    <div class="table-row">
        <div class="table-cell">
            <!-- ko if: svr.fShowCopyDebugDetailsLink --><!-- /ko -->
            <div class="override-ltr" data-bind="copySource: 'debugDetailsText'">
                <!-- ko if: debugDetails.errorCode --><!-- /ko -->
                <!-- ko if: svr.sessionId -->
                <div>
                    <span class="bold">Request Id: </span>
                    <span data-bind="text: svr.sessionId">3bf938fb-660a-419a-af80-500597752c00</span>
                </div>
                <!-- /ko -->
                <div>
                    <span class="bold">Correlation Id: </span>
                    <span data-bind="text: svr.correlationId">43cc427b-b649-420f-bde9-bd282dfe8b30</span>
                </div>
                <div>
                    <span class="bold">Timestamp: </span>
                    <span data-bind="text: debugDetails.timestamp">2022-03-30T16:33:16Z</span>
                </div>
                <!-- ko if: svr.strServiceExceptionMessage -->
                <div>
                    <span class="bold">Message: </span>
                    <span data-bind="text: unsafe_exceptionMessage">AADSTS50058: A silent sign-in request was sent but no user is signed in.</span>
                </div>
                <!-- /ko -->
                <!-- ko template: { nodes: $componentTemplateNodes, data: $data } -->
            <!-- ko if: $page.showConditionalAccessDebugDetails --><!-- /ko -->
            <!-- ko if: $page.paginationControlHelper.showErrorPageDebugDetails --><!-- /ko -->
        <!-- /ko -->
            </div>
            <!-- ko if: svr.urlSetDebugMode -->
            <div class="debug-trace-section">
                <div>
                    <span class="bold" data-bind="text: str['STR_Error_Details_Debug_Mode']">Flag sign-in errors for review:</span>
                    <a id="setDebugMode" role="button" aria-label="Enable flagging" href="https://login.microsoftonline.com/common/debugmode" data-bind="&#10;                        href: svr.urlSetDebugMode,&#10;                        text: isDebugTracingEnabled() ? str['STR_Error_Details_Debug_Mode_Disable'] : str['STR_Error_Details_Debug_Mode_Enable'],&#10;                        ariaLabel: isDebugTracingEnabled() ? str['STR_Error_Details_Debug_Mode_Disable_AriaLabel'] : str['STR_Error_Details_Debug_Mode_Enable_AriaLabel'],&#10;                        click: setDebugMode_onClick,&#10;                        hasFocus: isFocusActivated() &amp;&amp; !svr.fShowCopyDebugDetailsLink">Enable flagging</a>
                </div>
                <!-- ko if: sending --><!-- /ko -->
                <!-- ko if: debugModeError --><!-- /ko -->
                <div data-bind="text: str['STR_Error_Details_Debug_Mode_Desc']">If you plan on getting help for this problem, enable flagging and try to reproduce the error within 20 minutes. Flagged events make diagnostics available and are raised to admin attention.</div>
            </div>
            <!-- /ko -->
        </div>
        <div>
            <a id="errorBannerCloseLink" role="button" aria-label="Close troubleshooting details" href="#" data-bind="&#10;                click: hideBanner_onClick,&#10;                ariaLabel: str['CT_STR_Error_Details_Close_AltText'],&#10;                hasFocus: isFocusActivated() &amp;&amp; !svr.fShowCopyDebugDetailsLink &amp;&amp; !svr.urlSetDebugMode">
<!-- ko template: { nodes: [darkImageNode], data: $parent } --><img role="presentation" alt="Close troubleshooting details" src="https://aadcdn.msauth.net/shared/1.0/content/images/close_40eb39126300b56bf66c20ee75b54093.svg" data-bind="imgSrc, attr: { alt: str['CT_STR_Error_Details_Close_AltText'] }" svgsrc="https://aadcdn.msauth.net/shared/1.0/content/images/close_40eb39126300b56bf66c20ee75b54093.svg" pngsrc="https://aadcdn.msauth.net/shared/1.0/content/images/close_6278ec0ac116a229512ee5c448658b16.png"><!-- /ko -->
            </a>
        </div>
    </div>
</div>
<!-- /ko --></div>
        <!-- /ko -->
    </div>
</div>
<!-- /ko --></div>
        </div>
    </div>
    <!-- ko if: $page.paginationControlHelper.showFooterControl -->
    <div class="footer ext-footer" id="footer" role="contentinfo" data-bind="&#10;        externalCss: {&#10;            'footer': true,&#10;            'has-background': !$page.useDefaultBackground(),&#10;            'background-always-visible': $page.backgroundLogoUrl }">
        <div data-bind="component: { name: 'footer-control',&#10;            publicMethods: $page.footerMethods,&#10;            params: {&#10;                serverData: svr,&#10;                useDefaultBackground: $page.useDefaultBackground(),&#10;                hasDarkBackground: $page.backgroundLogoUrl(),&#10;                showLinks: true,&#10;                showFooter: $page.showFooter(),&#10;                hideTOU: $page.hideTOU(),&#10;                termsText: $page.termsText(),&#10;                termsLink: $page.termsLink(),&#10;                hidePrivacy: $page.hidePrivacy(),&#10;                privacyText: $page.privacyText(),&#10;                privacyLink: $page.privacyLink() },&#10;            event: {&#10;                agreementClick: $page.footer_agreementClick,&#10;                showDebugDetails: $page.toggleDebugDetails_onClick } }"><!-- ko if: !hideFooter && (showLinks || impressumLink || showIcpLicense) -->
<div class="footerNode text-secondary" id="footerLinks">
    <!-- ko if: showFooter -->
        <!-- ko if: !hideTOU -->
        <a class="footer-content ext-footer-content footer-item ext-footer-item" id="ftrTerms" href="https://www.microsoft.com/en-US/servicesagreement/" data-bind="&#10;            text: termsText,&#10;            href: termsLink,&#10;            click: termsLink_onClick,&#10;            externalCss: {&#10;                'footer-content': true,&#10;                'footer-item': true,&#10;                'has-background': !useDefaultBackground,&#10;                'background-always-visible': hasDarkBackground }">Terms of use</a>
        <!-- /ko -->
        <!-- ko if: !hidePrivacy -->
        <a class="footer-content ext-footer-content footer-item ext-footer-item" id="ftrPrivacy" href="https://privacy.microsoft.com/en-US/privacystatement" data-bind="&#10;            text: privacyText,&#10;            href: privacyLink,&#10;            click: privacyLink_onClick,&#10;            externalCss: {&#10;                'footer-content': true,&#10;                'footer-item': true,&#10;                'has-background': !useDefaultBackground,&#10;                'background-always-visible': hasDarkBackground }">Privacy &amp; cookies</a>
        <!-- /ko -->
        <!-- ko if: impressumLink --><!-- /ko -->
        <!-- ko if: showIcpLicense --><!-- /ko -->
    <!-- /ko -->
    <!-- Set attr binding before hasFocusEx to prevent Narrator from losing focus -->
    <a class="footer-content ext-footer-content footer-item ext-footer-item debug-item ext-debug-item" id="moreOptions" role="button" aria-expanded="false" aria-label="Click here for troubleshooting information" href="#" data-bind="&#10;        click: moreInfo_onClick,&#10;        ariaLabel: str['CT_STR_More_Options_Ellipsis_AriaLabel'],&#10;        attr: { 'aria-expanded': showDebugDetails().toString() },&#10;        hasFocusEx: focusMoreInfo(),&#10;        externalCss: {&#10;            'footer-content': true,&#10;            'footer-item': true,&#10;            'debug-item': true,&#10;            'has-background': !useDefaultBackground,&#10;            'background-always-visible': hasDarkBackground }">...</a>
</div>
<!-- /ko -->
<!-- ko if: svr.fShowLegalMessagingInline && showLinks --><!-- /ko --></div>
    </div>
    <!-- /ko -->
</div>
<!-- /ko --></div>
        <!-- /ko -->
        <!-- ko if: isVerticalSplitTemplate() && isTemplateLoaded() --><!-- /ko -->
    <!-- /ko -->
<!-- /ko --></div>
    <!-- /ko -->
</form>
<form aria-hidden="true" method="POST" target="_top" data-bind="postRedirectForm: postRedirect"></form></div><textarea tabindex="-1" class="moveOffScreen" id="debugDetailsText" aria-hidden="true">
Request Id:  3bf938fb-660a-419a-af80-500597752c00
Correlation Id:  43cc427b-b649-420f-bde9-bd282dfe8b30
Timestamp:  2022-03-30T16:33:16Z
Message:  AADSTS50058: A silent sign-in request was sent but no user is signed in.
     </textarea></body>
On 3/30/2022 at 1:23 PM, Jan Krohn said:
Delete all cookies on MSIE, then try again.
Hello, I just tried to use this tool again and now it doesn't want to work its showing the same error and I cleaned out my MSIE multiple times
  • 4 weeks later...
