Xp To Mac Transformation pack 3.5
http://osx.portraitofakite.com/
FlyakiteOSX is a transformation pack. It will transform the look of an ordinary Windows XP+ system to resemble the look of Mac OS X. The installer simply automates the process of replacing critical system files, setting registry tweaks, and installing extras such as cursors, sounds, visual styles, etc.
In case you are not happy with the results of FlyakiteOSX, everything is completely removable. Just run the uninstaller from the Start Menu or from Add/Remove Programs.
FlyakiteOSX does not contain any spyware or ad-ware of any kind. All files needed for FlyakiteOSX are stored in the Windows directory in a folder named
tnx bro.
this package will help me to costumise my unattended windows :)
Windows Leopard :D
CoOoming SOoOn :)
