September 28, 20223 yr I downloaded via Krohn ISO downloader the ISO for Windows 10 Pro 64 bit International English. The downloaded ISO file is named "Win10_21H2_EnglishInternational_x64.iso" - a strong indicator that I downloaded the correct ISO. But when I peek into these ISO files I got an unexpected build version: Version : 10.0.19041 (Full output see at the end of this posting). Now when I compare the build version with the version 21H2 should have then they are different. According e.g. to the table in Wikipedia https://en.wikipedia.org/wiki/Windows_10_version_history 21H2 should have a build version of ".....19044...." and not ".....19041 ....." Whats wrong? Output: Index : 1 Name : Microsoft Windows PE (x64) Description : Microsoft Windows PE (x64) Size : 1.766.536.550 bytes WIM Bootable : No Architecture : x64 Hal : <undefined> Version : 10.0.19041 ServicePack Build : 1288 ServicePack Level : 0 Edition : WindowsPE Installation : WindowsPE ProductType : WinNT ProductSuite : System Root : WINDOWS Directories : 4816 Files : 17217 Created : 07.12.2019 - 15:13:54 Modified : 06.10.2021 - 20:27:26 Languages : en-GB (Default) The operation completed successfully. Deployment Image Servicing and Management tool Version: 10.0.19041.844 Details for image : F:\sources\boot.wim
September 28, 20223 yr First, you should probe the install.wim, not the boot.wim I have the same result here, and it's normal, that's because from Windows 10 2004/20H1 to 21H2 the files are basically the same, the difference are only on logical level (with a registry key). Détails pour l’image : H:\sources\install.wim Index : 1 Nom : Windows 10 Famille Description : Windows 10 Famille Taille : 14 864 768 276 octets Peut être démarré par WIM : Non Architecture : x64 Couche HAL : <non défini> Version : 10.0.19041 Build du Service Pack : 1288 Niveau du Service Pack : 0 Édition : Core Installation : Client Type de produit : WinNT Suite de produits : Terminal Server Racine système : WINDOWS Répertoires: 27227 Fichiers : 99865 Création : 06/10/2021 - 15:43:42 Modification : 06/10/2021 - 20:17:27 Langues : fr-FR (Par défaut) If you don't believe me, just install the iso in a virtual machine.
