大†Shinegumi†大 Posted October 16, 2022 Share Posted October 16, 2022 (edited) Cheat Engine is an open-source tool whose sole purpose is to help you use tricks and cheats on your favorite video games, therefore allowing you to manipulate and change all sorts of parameters on them. This tool is very useful to find where some value (usually a number) is stored in the memory of a program. Usually numbers are stored in 4bytes form, but you could also find them in double or float formats, or you may want to look for something different from a number. Changelog: • IPT log can now be displayed as a tree in the format as "break and trace" • updated the tcc library to a more recent version • {$luacode} doesn't need dll injection to function anymore • auto assembler DB command has been updated to allow relative changes. e.g: DB +1 +2 will increase the bytes 'db' is done at with 1 and 2 respectively • you can't destroy luafile stream objects anymore. You now have to destroy the luafile itself • added more language support for AA scripts • added a new debugger interface: gdbserver (please let me know what and how you use it and the issues you have) • error out scripts that try to access GUI controls from other threads. (remove threadsafegui.lua if you don't want it. But it's there for a reason...) • tablist can't be clicked while scanning is active • removed the close button from the comments dialog • comments can now save empty spaces • memoryregion view columns can be sorted now •C code: ANDROID define set on android targets • lua: disassembler view now has a SelectionSize property • lua: caretX and caretY are now exposed to synedit • lua: TSynAutoComplete can be created (for those that want to implement autocomplete in lua/aa) • lua: ModuleLoader can now load streams and tablefiles (handy for dll injection without extracting the dll) Homepage: https://cheatengine.org Cheat Engine 7.5.2 Repack & Portable (15.7 MB) • Type: Install | Unpacking. • Languages: ML-7. • Removed: Bloatware. • System: x64 | x86 • Additionally: Extras languages added • Portable: Paf @jooseng • Extra: dbghelp.dll was removed for being able to run on Windows 7 Note: based on private developer patreon release: https://www.patreon.com/cheatengine Note: based on private developer patreon release: https://www.patreon.com/cheatengine Download: ///////////// Quote https://www.upload.ee/files/16502142/Cheat_Engine_7.5.2_Repack___Portable.zip.html https://mega.nz/file/zxNjTZTK#jXyIj9YS6SoqkfpfAPQ6lkeo6Vxuwfcq5XcBktJj7Po Edited Saturday at 04:32 PM by 大†Shinegumi†大 Quote Link to comment Share on other sites More sharing options...
大†Shinegumi†大 Posted Saturday at 04:34 PM Author Share Posted Saturday at 04:34 PM Changes: from patreon 7.4.3 to public 7.5: removed the driver requirement for the access memory regions tool added 1 byte jmp instructions (that will install an exeption handler and place an int3 at the location) added a scanoption so you can skip unpaged memory. (should prevent targets from eating up RAM when scanned) reassemble() now rewrites an instruction using multiple lines when needed make some error messages more descriptive added an option to center the highlighted disassembler code to the center added an explanation why the driver won't load and a link with info on how to get it to load for now memoryrecord hotkeys can now be disabled individually codefilter: unwind info now gives less bad results added support for pseudo-ops like cmpss/sd/ps/pd lua: added ceserver commands lua: show a stacktrace on execution error lua: added convertToUTF8(stringbytetable, regioncode) made loading CT files with signatures possible under wine and proton from patreon 7.4.2 to patreon 7.4.3: ceserver: pipe support (mono data dissector) ceserver: added change memory protection capability ceserver: Available options can now be sent to the CE GUI .netinfo: Replaced the fields view with a tree network config: The processlist now has focus after opening a server lua: added virtualstringtree lua: added invertColor lua: added disassembleBytes(bytestring) autoassembler: now a visual warning is shown when nearby allocation fails autoassembler: the templates now generate 14 byte jmp safe original code blocks as well pointerscan now has a deviation option for "pointer must end with offset" to help find pointers back after update ultimap: added copy selected results to clipboard from patreon 7.4.1 to patreon 7.4.2 ipt: Added intel process trace feature provided by microsoft. ceserver: Improve the modulelist fetch speed, more stable ceserver: option to disconnect from closed ceservers ceserver: the discovery list is now also a history list ceserver: implement injection on arm64 as well ceserver: also gets the fpu registers now assembler x86_64: prefer mov rax,[rip+xxx] over mov rax,[imm64] disasembler x86_64: switch from r#l to r#b because why not mono: the dll now has a versioncheck so that you don't accidentally mix monodatacollector dll's mono: deal with situations where there is no mainform mono/.net: the methodlist is now sorted by name better arm disassembler and assembler better arm64 disassembler and assembler the scanregions can be saved/loaded upon close/start ce (seperate option in settings) added an option to skip loading .PDB files a lot more functions are exposed to newstate threads added ranges scans to groupscan freeze+allow increase/decrease now also looks if the value is signed trainers: Forms and controls now scale based on DPI changing record showassigned/showashex now also applies to other selected entries texttraces now don't save as .cetrace but as .txt now ccode: #include now searches table files for files there as well ccode: the internal symbolhandler can now deal with stdcalled function symbols lua: added ImageIndex property to TTreeNode lua: added OnValuechanged and OnValueChangedByUser callbacks to MemoryRecord objects lua: added getOpenedFileSize() lua: added onHelpEvent callback lua: added releaseDebugFiles() lua: added enumRegisteredSymbolLists() and enumRegisteredSymbols() lua: added getBitmap method to ImageList objects from public 7.4 to patreon 7.4.1: added .Visible property to treenode entries added .VisibleRowCount and .TopItem to listviews added arm64 disassembling and assembling added lua function "runCommand" added a radiobutton to select if the generated script will use 5 or 14 byte jmps. conditional jumps can now deal 2gb+ destinations (will get rewritten) dotnetinfo: Performance improvement memory record hotkeys now have a "Only while down" option Updated the dbghelp to a more recent version which can better handle nowadys pdb symbols different memory allocations now get placed within the initial allocation block. Protection is changed afterwards tracer can now step over rep instructions lua stringstream now inherits from memorystream, so you have access to the Memory field lua: Added a callback for whenever the structure list is modified added architecture distinguishing to ceserver pressing escape in the hotkey form will now close it added nested structure support added string based custom types ctrl+enter in the disassembler now shows relative addresses from that point the diffcount in "find out what accessess/writes" will now stay even when disabling the option to find the number of different addresses an instruction accesses Fixes: from patreon 7.4.3 to public 7.5: vehdebug: Fixed a case where a new thread creation or other event would cause another event that would trigger at exactly the same time to get the exception ignored and just continued monodatacollector: fixed invoke method dotnetdatacollector: Fixed issue of loading a wrong version of dbgshim.dll fixed disassembling cvtdq2pd from patreon 7.4.2 to patreon 7.4.3: ceserver: Fixed extension loading in some cases ceserver: fixed stepping on x86 targets fixed the name showing as [physical memory] instead of the filename when opening a file fixed a rare error when scanning using specific options fixed some documentation in celua at some points fixed stackview in "more info" being garbage/access violation fixed tracer search for instructions ending with ] fixed enumExports lua function fixed issue where vehdebug would crash fixed the assembler from handing [rex+reg*x] as a symbol when debugging fixed the disassembler backlist fixed termination issue on the memscan object from patreon 7.4.1 to patreon 7.4.2 Fixed the tracer search for instructions ending with a ] VEH debug: Fixed the potential of invalid handles being used Kernelmode debug and VEH debug: Fixed setting context on non suspended threads fixed the lua_pcallk delegate in the c# plugin example fixed speedhack on wine 7.0 fixed high dpi issue of structure dissect on first view fixed high dpi issue on find what access/writes dialogs restored the anchor editor (was gone in 7.4.1) fixed .net info instance lookup issue fixed customtypes getting marked as string (bug introduced in 7.4.1) fixed runcommand fixed modalforms from losing their text color internally (bug introduced in 7.4.1) mac: fixed some progressbars not properly updating from public 7.4 to patreon 7.4.1: fixed the all type not finding 4 types when double was deselected fixed the "all" type when not using double fixed ccode esp access in 32-bit and "reg"f types fixed disassembling when using binutils for disassembly fixed the tablefiles menulist eating memory because they didn't get deleted properly fixed .net issues that use obfoscated modules and missing metadata fixed paring value starting with a - or + fixed assembling pmovmskb fixed disassembling vgather* vex256 instructions and allow usage of xmm/ymm registers as address (for instructions that allow it. Like this one) fixed the addresslist not giving a proper error when using multiple enable or disable section fixed error when using ctrl for speedhack hotkeys fixed the groupscan command parser from assigning wildcard to the wrong combobox fixed disassembling xchg eax/rax,xxx fixed lua custom type registering as float when using the non lua function method fixed small memoryscan issue for data at the end of a memoryblock ccode doesn't register useless symbols anymore Quote Link to comment Share on other sites More sharing options...
