December 30, 200718 yr I know I had cancelled the old one but I have decided to rebuild this using the regentry format!Website: http://www.angusj.com/resourcehacker/ Size - 435kb Hash = F91D36BAA7DE3244630268FB3F3A7FB8The updated help file has been included...
February 9, 200818 yr Can you tell me how to add a shortcut in sendto context menu section in this addon
February 9, 200818 yr Author profileitems = reshack[reshack]Name = Resource Hacker,0x00000008,9CmdLine = 11,,ResHacker.exeWorkingDir = 11
February 10, 200818 yr profileitems = reshack[reshack]Name = Resource Hacker,0x00000008,9CmdLine = 11,,ResHacker.exeWorkingDir = 11I added the lines to the INF & installed it using the INF but when i right click a .dll file i don't see open with reshack and when i hover my mouse over SendTo Submenu i don't see Reshacker.Here is what i did:[Version]Signature=$Windows NT$[defaultinstall]AddReg =Reshackcopyfiles =main.copyprofileitems = reshack[Optional Components]Reshacker[reshacker]OptionDesc ="Extra Control Panels"Tip ="Extras"Modes =0,1,2,3AddReg =Reshackcopyfiles =main.copyprofileitems = reshack[reshack]Name = Resource Hacker,0x00000008,9CmdLine = 11,,ResHacker.exeWorkingDir = 11[sourceDisksNames.x86]1="Program Main Files","ResHack.cab",,"i386"[DestinationDirs]main.copy = 11[sourcedisksfiles]ResHacker.cnt =1ResHacker.exe =1ResHacker.Hlp =1[Main.copy]ResHacker.cntResHacker.exeResHacker.Hlp[ResHack]HKCR,"CLSID\%CLSID90%"HKCR,"CLSID\%CLSID90%",,,"Resource Hacker"HKCR,"CLSID\%CLSID90%","InfoTip",,"Allows modification of most file types."HKCR,"CLSID\%CLSID90%\DefaultIcon",,,"%11%\Reshacker.exe"HKCR,"CLSID\%CLSID90%","{305CA226-D286-468e-B848-2B2E8E697B74} 2",0x10001,02,00,00,00HKCR,"CLSID\%CLSID90%\ShellFolder","Attributes",0x10001,00,00,00,00HKCR,"CLSID\%CLSID90%\Shell\Open"HKCR,"CLSID\%CLSID90%\Shell\Open\command",,,"Reshacker.exe"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\%CLSID90%"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\%CLSID90%",,,"Add Reshacker to The Control Panel"[strings]CLSID90 ="{D14ED2E1-C75B-443c-BD7C-111111111190}"Am i doing something wrong? Do i have to add any line to the Entries_ResHack.ini?java script:add_smilie("","smid_13")
February 11, 200818 yr Author [Version]Signature=$Windows NT$[defaultinstall]AddReg =Reshackcopyfiles =main.copyprofileitems = reshack.short[Optional Components]Reshacker[reshacker]OptionDesc ="Extra Control Panels"Tip ="Extras"Modes =0,1,2,3AddReg =Reshackcopyfiles =main.copyprofileitems = reshack.short[reshack.short]Name = "Resource Hacker",0x00000008,9CmdLine = 11,,ResHacker.exeWorkingDir = 11[SourceDisksNames.x86]1=Program Main Files,"ResHack.cab",,"i386"[DestinationDirs]main.copy = 11[sourcedisksfiles]ResHacker.cnt =1ResHacker.exe =1ResHacker.Hlp =1[Main.copy]ResHacker.cntResHacker.exeResHacker.Hlp[ResHack]HKCR,"CLSID\%CLSID90%"HKCR,"CLSID\%CLSID90%",,,"Resource Hacker"HKCR,"CLSID\%CLSID90%","InfoTip",,"Allows modification of most file types."HKCR,"CLSID\%CLSID90%\DefaultIcon",,,"%11%\Reshacker.exe"HKCR,"CLSID\%CLSID90%","{305CA226-D286-468e-B848-2B2E8E697B74} 2",0x10001,02,00,00,00HKCR,"CLSID\%CLSID90%\ShellFolder","Attributes",0x10001,00,00,00,00HKCR,"CLSID\%CLSID90%\Shell\Open"HKCR,"CLSID\%CLSID90%\Shell\Open\command",,,"Reshacker.exe"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\%CLSID90%"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\%CLSID90%",,,"Add Reshacker to The Control Panel"[Strings]CLSID90 ="{D14ED2E1-C75B-443c-BD7C-111111111190}"You had 2 [reshack] sections whaic was causing a conflict.
March 18, 200818 yr first thanks kel for this addon so i want to know wherei wan find the string in right clic of context menu of reshack anyone know where please and thanks.
March 18, 200818 yr Author There is no right click entry in the defualt addon. You need to add it or ask me to modify mine to put one there.
March 18, 200818 yr There is no right click entry in the defualt addon. You need to add it or ask me to modify mine to put one there.yeah kels i want it and tell me wich section do you add it (in note.inf or what else) than i can change it for my own words and thanks a lot kels
March 18, 200818 yr Author add this to profileitems = ,reshack.shortThen put this in the .inf anywhere [reshack.short]Name = Resource Hacker,0x00000008,9CmdLine = 11,,ResHacker.exeWorkingDir = 11Thisw will make a shortcut in your sendto menu.
March 20, 200818 yr add this to profileitems = ,reshack.shortThen put this in the .inf anywhere [reshack.short]Name = Resource Hacker,0x00000008,9CmdLine = 11,,ResHacker.exeWorkingDir = 11Thisw will make a shortcut in your sendto menu.thanks kels but if possible i would like to have the mention(eg edit with notepad++ or whatelse...) without using the send to menu its like when you install reshack by using his exe he creates by default this mention at the right clic in context anyway of doing this (this can be done by some reg tweaks i think but i don't know the key) ? Edited March 20, 200818 yr by ferigno1
