Script Request
I run and maintain a large cmd file to rearrange my start menu and add shortcuts that aren't there to begin with.
Is it possible for someone to write a script that uses "shortcut.exe" or similar method to automatically create shortcuts out of all the files in a directory and place them in a designated area?
A GUI would be awesome, but I'm assuming too much work for a small project like this.
I don't like moving shortcuts around, I would much rather recreate them where I want them. Shortcut works for that but it's a pain to write a command line for every file.
It will be for personal use. Basically I need a script that will run a loop through all files in a directory.
I'm not sure if you're familiar with the shortcut program I am using. I'm not even sure where I got it anymore. The syntax is:
shortcut.exe /F:"%Filename%" /a:c /T:"%Target%" /W:"%Working Directory%" /I:"%Filename%,0"
shortcut.exe resides in my system32 directory. if you could use that structure and make the filename, target, and working dir variables I could manage the rest.
I started learning C++ a few years ago and stopped because the next class was never offered! I have an idea of what I need but I don't know the syntax for the command line or vbscript. I only learned concepts in C++ we never got to the point where we could use the file system.
This isn't in vbscript, but it should be easy enough with 2 batch files.
first.bat
@echo off
xcopy /L "your folder here\*" temp\ > list.txt
FOR /F "tokens=1* delims=~" %%i IN (list.txt) DO SET filename=%%~nxi&set target=%%~fi&set working_directory=%%~dpi&call second.bat
second.bat
%windir%\system32\shortcut.exe /F:"%Filename%" /a:c /T:"%Target%" /W:"%Working Directory%" /I:"%Filename%,0"
Try this and see how it works.
