Booting problems
Hello all!
I got a little problem.
I have this desktop machine, and my CD/DVD drive is a USB one. I can see it and the harddisks in BIOS options, but when I try to boot into system, or try to boot from an XP CD (which I has tested on another computer, and it worked well) and I have tried with another older XP cd.
Every time I try to boot from an XP CD it says that I should reboot my system and connect a right bootable device. When I try to boot from harddisk which already has XP installed on it, it says that some nddr thing is missing and that I shouls press CTRL+ALT+DEL to reboot. I thought it was my motherboard because sometimes my computer was turning off, so I bought a new one today, but the same thing (can't boot) happens with this one too. I've tried many different harddisk and still same thing (both SATA and IDE).
And btw, when I insert the motherboard driver CD, it boot without problems.
I hope you can help me on this one guys. :D:)
ANY help is appreciated.
Edited by Mr.Thunderbird
