Posted June 18, 200817 yr Console 2 AddOn v1.0.0Console is a Windows console window enhancement. Console features include: multiple tabs, text editor-like text selection, different background types, alpha and color-key transparency, configurable font, different window styles.This AddOn includes :Console 2A modified version of Open cmd Here to make it launch Console 2 instead of classic cmd.exe. As this software comes under GPL licence, modified source are avalaible here.Cmd Open Prompt has been compiled using Visual C++ 2008, so it needs latest visual C++ dlls to be registered. That's why I included ASMS folder within the AddOn. This one comes from Kel's Runtimes : thanks goes to him!ChangeLogv1.0.0 : Initial ReleaseCRC32: 3CE1E776MD5: 222B412884464AAE31B0765FA379320FSHA-1: 986310C7DD1AD167B697F1931458FB1D96EC8901Size: 5.97MB Edited June 18, 200817 yr by Kal
June 19, 200817 yr would this in any way affect a color tweak i have applied for my normal CMD? thanks!
June 24, 200816 yr Is the asms folder supposed to be in the package?edit:d'ohAs this software comes under GPL licence, modified source are avalaible here. It has been compiled using Visual C++ 2008, so it needs latest visual C++ dlls to be registered. That's why I included ASMS folder within this AddOn. This one comes from Kel's Runtimes : thanks goes to him!anyway, is it safe to delete the 5mb folder? Edited June 24, 200816 yr by bl_nk
June 24, 200816 yr Author Is the asms folder supposed to be in the package?edit:d'ohanyway, is it safe to delete the 5mb folder?No, it's not safe. The "open command promp right clik" won't work.Kal
