I just made a XPCD with SP3 and the product key is no longer working. I forgot what I was supposed to do but there is a file or something that has to be changed. Can anyone help me?
THANKS
Luzr4life, use corporate xp...
I think your xp is OEM so that happened to you...
I know because that happened to me too...
I am using a Corp. Edition. I believe when you had a service pack 3 you need a PS3 prod. key. Awhile back I made one and there was a file that I had to replace from a SP2 CD that enables the SP2 prod. key to work on SP3.
