Delete shortcut depending?
Ok....
I'm working on a addon for O&O SafeErase 3....
The addon works perfectly.....
I have one problem....
I create the shortcut just like the default installer does....
Start/All Programs/O&O Software/O&O SafeErase....
I can delete it also with no problem.....
The problem comes in if you have more that 1 O&O software installed...
Reason being that O&O creates shortcuts to all their software in:
So what you could have is shortcuts like this:
Start/All Programs/O&O Software/O&O Defrag
Start/All Programs/O&O Software/O&O etc........
So when my addon is uninstalled I need it to check to see
if any other shortcuts exists there.... If so ONLY delete
the O&O SafeErase part.... If not, delete the whole thing.....
Hope I explained it clear enough......
Right now this is the code I'm using......
[Program.DelShortcut]
Name =O&O SafeErase Wizard,0x00000002
SubDir=O&O Software\O&O SafeErase
[Program.DelShortcut1]
Name =O&O SafeErase Help,0x00000002
Of course this is just standard...
Ok... I await the gods of addons suggestion! :D
You need not worry about deleting the other prog shortcuts...my sidebar addon puts a shortcut in the accessories subdir and when i delete the shortcut the other shortcuts are left untouched
Umm, rick you didnt understand him imo. He wants a code, that will uninstall the shorcut first, but then, if the shortcut folder is empty, will delete the folder too. The folder exists in start menu-programs dir of user.
Sorry reaper, i cant think of anything right now. Will inform you if i find something usable ;)
Anyone have any more ideas on this???
I know its a weird situation...
And under most instances would not matter....
Unless the user has multiple O&O programs.....
You could use a call to command prompt - calling a batch file that will perform the test and delete if necessary. rick can help with the syntax. But, I have used this in the past to create a service using vbscript. This is what I used to create the service.
[Install]
RunPostSetupCommands =Create.Service:1
[Create.Service]
CMD /Q /C cscript //nologo """%programfiles%\%scripts_dir%\InstallService.vbs"""
Creating a batch file should be easy enough. I can help with it if you need it.
