REQ:- Sun Java Runtime 6 update 11 Addon?
Take that silent installer and make yourself a addon, if you cant do this you should quit making unattended stuff:
- Make a new folder called SVCPACK and put Kels silent installer in it
- Now create a New->Text Document and rename it Entries_JRE.ini and add the following
; Java Runtime Environment addon py kelsenellenelvian |
[general]
builddate=2008/12/16
description=Java Runtime Environment.
language=Multilanguage
title=Java Runtime Environment
version=6.0.110.3
website=http://www.java.com/
[EditFile]
I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram
[AddProgram]
Java6u11.exe
- Zip, Rar, Cab or 7-Zip the Entries_*.ini and SVCPACK folder together and name it Kels_JRE1.6.0_11_addon
[general]
version=6.0.110.3
[EditFile]
[AddProgram]
Java6u11.exe
Thank you very much Rick..appreciated
