Want to submit an addon?
To submit an addon, a specific layout has to be applied.
An example is below with all the relevant pictures you can use. Popular addons will be added to W7T "Addons" list. To be honest... as long as it is neat and tidy you don't have to go by this template :)
Homepage button
[url="http://www.example.com"][img=http://www.wincert.net/forum/uploads/monthly_03_2008/post-4451-1205416740.png][/url]
Download button
[url="http://www.example.com/example.exe"][img=http://www.wincert.net/forum/idm_setup/images/tabdownload.png][/url]
Size
[img=http://www.wincert.net/images/forum/size.png]
MD5
[img=http://www.wincert.net/forum/uploads/monthly_03_2008/post-4451-1205780671.png]
Note: I did not make the pictures above.
Edited by Legolash2o
Just a note...
Users who use file hosting sites like RapidShare, i can not add those addons to the Addon list within W7T, as it can only work with direct links. So if you can use FTP or anything that can provide a direct link then that would be great.
If you do not have access to anything like that then just continue using RapidShare, etc... Thanks.
Lego
