February 2, 200917 yr [HKEY_LOCAL_MACHINE\HKLMSoft\3Planesoft\Ancient Castle 3D Screensaver]"SerNum"="3: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx""RegName"="3: xxxxxxxxxxxxxxx"HKEY_LOCAL_MACHINE\HKLMSoft = HKEY_LOCAL_MACHINE\SoftwareHKEY_LOCAL_MACHINE\HKLMDefault = HKEY_Users\.DEFAULTHKEY_LOCAL_MACHINE\HKLMSoft\Classes\ = HKEY_Classes_RootFor example if you want to change...[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Mozilla\Minefield\3.2a1pre (en-US)\Main]"Install Directory"="C:\\Program Files\\Minefield""PathToExe"="C:\\Program Files\\Minefield\\firefox.exe""Program Folder Path"="C:\\ProgramData\\Microsoft\\Windows\\Start Menu\\Programs\\Minefield""Start Menu Folder"="Minefield"In your Minefield.VA addon it would have to be changed to[HKEY_LOCAL_MACHINE\HKLMSoft\Wow6432Node\Mozilla\Minefield\3.2a1pre (en-US)\Main]"Install Directory"="C:\\Program Files\\Minefield""PathToExe"="C:\\Program Files\\Minefield\\firefox.exe""Program Folder Path"="C:\\ProgramData\\Microsoft\\Windows\\Start Menu\\Programs\\Minefield""Start Menu Folder"="Minefield"it would be easier just to use the replace tool in notepad and change all "HKEY_LOCAL_MACHINE\SOFTWARE\" to "HKEY_LOCAL_MACHINE\HKLMSoft\" and etc...hope that has helped the addon integrator for W7T (which will work for vista) will be alot easier to create addons and eventually include an addon creator tool too
