March 20, 200916 yr Hola a todos.. necesito saber como hacer una instalacion desatendida de ese antivirus en espa
March 20, 200916 yr I install ACG Free 8 & 8.5 using these parameters./HIDE /NO_WELCOME /NOAVGTOOLBAR /DONT_START_APPS /REMOVE_FEATURE fea_AVG_SafeSurf /REMOVE_FEATURE fea_AVG_SafeSearch /ADD_FEATURE fea_AVG_EmailPlugins /ADD_FEATURE fea_AVG_EMC
March 20, 200916 yr Author probe varios entre ellos: /LANG=SPANISHhasta ahora tengo un metodo que es instalando en espa
March 20, 200916 yr I don't think it has such a parameter.Never seen it been used yet.You may try copying the config files with the new installation. The files are located at:%allusersprofile%\Application Data\avg8\cfg\May someone please translate? I don't want to use Google Translate.(:
March 21, 200916 yr I install ACG Free 8 & 8.5 using these parameters./HIDE /NO_WELCOME /NOAVGTOOLBAR /DONT_START_APPS /REMOVE_FEATURE fea_AVG_SafeSurf /REMOVE_FEATURE fea_AVG_SafeSearch /ADD_FEATURE fea_AVG_EmailPlugins /ADD_FEATURE fea_AVG_EMCWow good code ...001 ... fijate con /LANG=SPA o ES o SPA ... o como se te ocurra para acortar espa
