In this tutorial you will learn how to add that trendy smooth gloss effect to your shapes, text and objects in Photoshop. Its a universal effect and can make most aspects of a design look really sleek and attractive.
Step 1
The first step to this tutorial is to create your shape on a blank canvas. *Note that this isn't how you have to do it all the time, but for the sake of learning this is the quickest and easiest way to grasp the technique. For this tutorial, well use a rounded rectangle shape:
*Note, this can be done with any shape you like. We are using the rounded rectangle as an example only. The technique can be applied to text, shapes and most objects in Photoshop.
Step 2
Now that you have your basic shape, you can start to construct the glossy effect that this tutorial is all about. Your first task in this stage is to make the selection for the area that you want to add the gloss to. This is the trickiest part of the whole effect, so you need to be a little careful.
To select the entire area of the shape, move yourself over to the layers window (accessible also from Window > Layers on the top menu) and left click on the shape layer only once. While holding down the CTRL key on your keyboard left click the shape layer once more and it will create a selection around the shape for you. The outcome should look like this:
Step 3
Now that you have your basic selection as seen above, its time to trim some of that away so that you get your base for creating the amazing gloss effect that you want. The next thing for you to do is to create a new layer by clicking the New Layer icon that can be found at the bottom of the Layers Window:
Once you have your new layer you are almost ready to start adding your gloss effect, however you still have to limit your selected area. To do this, select the square marquee tool from the toolbar and set the controlling power to the one shown here:
Now that your tools are set, its time to select the area you want to gloss. For the sake of the tutorial and for you to pick the technique up quicker, drag a square selection from above the current selection down to about half way into the shape and let go of the left mouse button. You should end up with a result that looks like this:
*Note, other selections can be made by experimenting with the circular marquee and the lasso tools.
Step 4
Now its time to actually make this gloss effect visible. Select your gradient tool from the toolbar and set the controlling power to the one shown here:
Its important for your foreground colour to be set to white. This will be the only colour that you can use to achieve the gloss effect properly. Now that you have your selection and your tools ready its time to get to business.
Step 5
Take your gradient tool, and drag downwards from just above the top of your shape, to just below where your selection ends. Once you have done this hold on CTRL and then tap the D key, this will deselect the area. You should achieve a result looking like this:
now all you have to do is select the first layer by clicking the layer preview and pressing ctrl while clicking
go, Edit>Stroke, outline selection>change the weight to 2px chose a dark red color and the outside stroke option and click OK
all finished :D
again, don't be afraid to bend the rules of photoshop to make it look perfect ;)
Up next: Vista Glass
Hmm, the images seem to be dead. But this is one of the best glass-effect tutorials I've seen yet! (Way better than the "uh... gradient red white top bottom.")
I suppose it was on purpose to save bandwith :) Firefox + Tabs ftw!
  • 1 year later...
