How to edit Add-On
Hi. I'm sorry, I can't find it on forum, becouse I'm from Poland, and I can't speak English very good. In this post you can see my level of english language ;p
Ok. I have Kels_CPLBonus_v9.4.8.exe. I unpack it, and I have files, and instalator informator (CPLBonus.inf). I delete entry from this .inf file, whos I wanted, and file from folder. But how can I now pack it to .exe, with Switchless Installer ? In what program ?
What you need to do is use a cabtool to cab all of the files program files together, then cab or 7z the cab file you made with the 2 .inf's and your done.
Naw he is using the switchless installer.
Download WinRAR.
Right click on the .exe and "Open With WinRAR"
Choose and delete the files you want.
Drag the new .inf into the window and it will overwrite the old one.
OK, sorry Kel. I saw (CPLBonus.inf) in the topic and though all of the switchless installers were done with (entries). LOL. I have been out to long
Thanks man ;) It works. I earlier try edit this in 7-Zip, but when I want save file, it show mi dialog:
This interface is not supported
. In Winrar everything is ok.
Edited by pietreXtreme
