Hi Guys just try Toolkit for my Vista SP2 installation. but under Vista SP2 updates i cant find the KB951847 Microsoft .NET Framework 3.5 Service Pack 1 and .NET Framework 3.5 Family Update x64. will this update be included in Toolkit soon.
Kind regards
THXMAN
I cant seem to finda download link to add them, i will continue looking :)
Welcome to Wincert :D
well .Net Frame 3.5 Sp1 Link
Full Package if you need it in here
.Net Frame Family Update for X64 here
i think this is what you need
Edited by DaRk MaDnEsS
Hi again i think you can get it here http://catalog.update.microsoft.com/v7/site/search.aspx?q=951847
on windows update it says the size is 50,2MB update. i will download it and try to install it. to see if it goes away from windows update after i install KB951847
kind regards
THXMAN
well the reason it's only 50 mb that it's only the needed files
the full pack have windows xp and windows vista files and 64 bit files
so if you remove the unneeded it would be 50 mb
