August 6, 200916 yr Hey guys help me man , problem is here .. please tell me what i did wrong this time..My nlite file: http://pastebin.com/m66314e10i used untouched VLK ISO. and just instered txt mode sata drivers by using driverpack.net utility before using nlite.regardsEDIT: thats problem has been resolved now the issue is the addons not showing up thx Edited August 8, 200916 yr by rollcage
August 6, 200916 yr Hey guys help me man , problem is here .. please tell me what i did wrong this time..My nlite file: http://pastebin.com/m66314e10i used untouched VLK ISO. and just instered txt mode sata drivers by using driverpack.net utility before using nlite.regardsdid you integrate the driver then used nlite to remove some drivers or components ?you need to use driver pack just before making the cd
August 6, 200916 yr you should really be asking in the nlite forum. wincert doesnt support nlite or troubleshoot since they didn't create it. best to ask at the official nlite forum
August 6, 200916 yr Author thx guys i will keep that in mind .. and@ DaRk MaDnEsSI think that is my problem, using driverpack base before using nlite. thx for the tip.Secondly, Kindly take a look at ini file, am I adding too much of addons?or Is there any addon that gonna contradict with others.. please suggest. Regardsrollcage
August 6, 200916 yr thx guys i will keep that in mind .. and@ DaRk MaDnEsSI think that is my problem, using driverpack base before using nlite. thx for the tip.Secondly, Kindly take a look at ini file, am I adding too much of addons?or Is there any addon that gonna contradict with others.. please suggest. Regardsrollcagewell just use nlite and do what you want on a clean cd then use driver pack and i gonna see the ini nowEdit:since you are using onepiece Addon just first run just remove the component you don't need then rerun Nlite intergate Only Update Packs like OnePiece then rerun Nlite and added other programs then finally use driver pack Edited August 6, 200916 yr by DaRk MaDnEsS
August 6, 200916 yr Author ok if you say so i try that. i trust you bro.and.. is there anything that i can delet out of that .. that i am missing.
August 6, 200916 yr Author I just tried it.. i think i am missing something in this.though that error is gone but i am doing some mistake. bcoz Windows Media Player 11 hasnt come and most of the addons are missing.
August 6, 200916 yr I just tried it.. i think i am missing something in this.though that error is gone but i am doing some mistake. bcoz Windows Media Player 11 hasnt come and most of the addons are missing. hmm you mean that the windows looks in classic mode and true addon doesn't exist only svcpack addon if that then go to %windir%\system32 and search for setuperr.logit should have the error that happens upload it i might see where is the problem
August 8, 200916 yr Author hmm you mean that the windows looks in classic mode and true addon doesn't exist only svcpack addon if that then go to %windir%system32 and search for setuperr.logit should have the error that happens upload it i might see where is the problemI am very sorry bro, I was stucked in Audits deadlines of the moonth end at office and thereby couldnt reply. ya a geek inside a an auditor poor me. lolI mistakenly deleted the VM Ware file so installed again now, I made the two isos, one before adding txt drivers and one adding them. so this one is that. the previous one i tried was of the full in the end iso, i mean after adding the txt driver, and i did how you advised / as in - in the last, not like my initial mistake of doing it exactly opposite. now what i did was, 1st removed the components, then added that update pack onepiece addon, then other addons + tweaks + unattend (no drivers) + then in the last I added the txt drivers only by DriverBase app, the used nlite to make an iso. done. installed using VMWare.anyways here is the log file.. between i found it in Windows directory root, not winodowssystem32, is there a difference!so does this file recods everything that going on? thx in advance dearnow it installed fine.. but i think i am adding too many addons, shall i scrap the trail run now, bcoz not everyone can be eXP, and its time to shift to win7 anywas. also I just tried the Tiny7, just installed it on my gaming pc, and then tried it today on a old desktop of P4 + 512mb, and beleive it or not its damm good, surprised me. and i just wish it was in x64. have you tried it?sorry again for late reply.Regardssetuperr (rollcage).zipedit: typo'sedit 2: .. added the screenshot for your reference. thx, Edited August 8, 200916 yr by rollcage
August 9, 200916 yr Enough talk of trying this and that type of warez!You are getting that error because one of your addons is not being processed properly thus causing a chain reaction.Any ,ore talk of warez and I will give you an official warning.Wait untill the 22nd of October and buy your Win7! Quit cheating and making things harder on us legitimate users!
August 9, 200916 yr Author Enough talk of trying this and that type of warez!You are getting that error because one of your addons is not being processed properly thus causing a chain reaction.Any ,ore talk of warez and I will give you an official warning.Wait untill the 22nd of October and buy your Win7! Quit cheating and making things harder on us legitimate users!ohk got your point bro2. i wont cheat bro, i have original 98se, 200me, XP, and soon i will buy Win7, i just skipped the vista.I have audit firm so we buy VLK so. i work as an auditor.3. i was just making this to try out myself, i have tried it ealier but this time. my mind is not working properly4.and kels dude.. I think i am interacting with you for the first time, but i must say thanx for all those sweet addons.. hats off .. thx a ton for those. that has been helping for years now. the simple xp that we get from M$, then ur addons make it so cool thx again.as for this topic.. if you say so its stand withdrawn. the end.. you said i follow bro. thx.Reagrds
August 9, 200916 yr ohk got your point bro2. i wont cheat bro, i have original 98se, 200me, XP, and soon i will buy Win7, i just skipped the vista.I have audit firm so we buy VLK so. i work as an auditor.3. i was just making this to try out myself, i have tried it ealier but this time. my mind is not working properly4.and kels dude.. I think i am interacting with you for the first time, but i must say thanx for all those sweet addons.. hats off .. thx a ton for those. that has been helping for years now. the simple xp that we get from M$, then ur addons make it so cool thx again.as for this topic.. if you say so its stand withdrawn. the end.. you said i follow bro. thx.Reagrdswell rollcage i can't see where is the error from so just do this steps just first run just remove the component you don't needthen rerun Nliteintegrate Only Update Packs like OnePiece then test in vmware then just add programs but not all at one just 3 or 4 programs not all at once
August 9, 200916 yr Author well rollcage i can't see where is the error from so just do this steps then test in vmware then just add programs but not all at one just 3 or 4 programs not all at onceok i try that.. ya one by one.. but its a killing process man. i dont get much time from office . then presentations and all. dammm.ok i try that againand what you say XP or Win7 now. considering configs are 1GB ram. ya that 1gb case is in dialama. not like my pc at home where it can be tried with 6gigs but at office its different ball game. Edited August 9, 200916 yr by rollcage
August 9, 200916 yr Like D said, 1. Start nLight) remove components. (only) close2. Start nLight) Add update packs.(only) make ISO then Test in a VM3. Start nLight) Add your addons 1 at a time (only) make ISO, then Test in a VM4. Start nLight) do all your tweaks, patches, and unattended, make ISO, then Test in a VM
