How i can do in CMD + - / *?
well lets say you have to variable and you want to + them into a new one
set /a x=1
set /a y=2
set /a z=%x%+%y%
i hope that helped
Characters with special meaning for the interpreter must be prefixed by a caret (^) to behave as normal ones. so type ^&.
Or enclose the text with quotes:
copy /y "%systemdrive%\test\*" "%systemdrive%\test2\*"
*Edit,
Oh, nevermind. I just caught you want to add, subtract, multiply & divide.
Dark Madness got it.
Edited by Mr_Smartepants
set /a x=1
set /a y=2
set /a z=%x%+%y%
i hope that helped
THX, i will try it. I want use it with IF...
if "%I%" == "2" DO set ULT=%I%+1
Will this work?
Will this work?
well you need to add /a after set
that will active math mode
and in that if you don't need the do
so the code well be simple
if "%I%" == "2" set /a ULT=%I%+1
and in that way
wouldn't it be easy to make the last code like that
if "%I%" == "2" set /a ULT+=3
it would do the same trick
ULT+=3 mean add on ULT 3 and it also equal ULT=%ULT%+3
edit :
sorry for the last code i made it wrong the one i made would add
so it should be
if "%I%" == "2" set /a ULT=3
my mistake :blink:
Edited by DaRk MaDnEsS
and in that way
edit :
so it should be
my mistake :blink:
Tomorow i will work on my W7I CMD and will try it THX
EDIT:
Sorry, i have 1 question how make this:
if not "%MSU%" == "1" and "%CAB%" == "1" goto :_Error
I think if MSU and CAB not 1 goto :_Error
EDIT2:
Does somebody know how read how many files (*.rar, *.zip, etc etc..) are in folder?
Edited by George King
EDIT:
EDIT2:
that should work
if not "%MSU%" == "1" if not "%CAB%" == "1" goto :_Error
LOL yeah me :D
i will test the code and tell you
edit:
made it
set count=0
for /f %%a in ('dir /b *.exe') do set /a count+=1
echo %count%
Thanks Darky... Your script work, but in my script work only for *.cab. Dont know why...
@echo off
title Windows 7 Updates Installer by George King v1.1.0
cls
if exist Windows6.1-KB968771-x*.msu set IE=- IE 8 Feature Pack
echo.
echo +++++++++++++++++++++++++++++++
echo + Windows 7 Updates Installer +
echo.
echo.
echo Searching for MSU Updates...
echo.
echo.
if exist Windows6.1-*.msu (set MSU=1
set COUNT=0
for /f %%a in ('dir /b *.msu') DO (set /a COUNT+=1
set M=%COUNT%
echo.
echo Windows 7 Updates Installer found %M% * MSU * Updates
echo.
goto :_CAB
) ELSE (echo *******
echo No * MSU * Updates in current folder...
echo *******
goto :_CAB
:_CAB
echo.
echo Searching for CAB Updates...
echo.
echo.
if exist *.cab (set CAB=1
set COUNT=0
for /f %%b in ('dir /b *.cab') DO (set /a COUNT+=1
set C=%COUNT%
echo.
echo Windows 7 Updates Installer found %COUNT% * CAB * Updates
echo.
goto :_Install
echo No * CAB * Updates in current folder...
echo *******
goto :_Test
:_Test
if not "%MSU%" == "1" if not "%CAB%" == "1" goto goto :_NoUpdates
:_Install
echo.
echo ***************************************************
echo * Press any key for start updating your system... *
pause >nul
cls
echo.
echo.
if "%MSU%" == "1" (echo Installing MSU Update:
FOR %%U IN (*.msu) DO (echo %%U %IE%
"%%U" /quiet /norestart
echo.
if "%CAB%" == "1" (echo Installing CAB Update:
FOR %%C IN (*.cab) DO (echo %%C
DISM /Online /Add-Package /PackagePath:%%C >nul
echo.
echo Please REBOOT your computer for complete installation...
pause >nul
exit
:_NoUpdates
echo.
echo Updates not found!!!
echo.
echo Please place this file (Update.exe) into folder with MSU or/and CAB updates...
echo After place Update.exe into folder with updates installation will start...
echo.
pause >nul
exit
@echo off
cls
echo.
echo.
echo.
echo.
echo.
set COUNT=0
set M=%COUNT%
echo.
echo.
goto :_CAB
echo *******
goto :_CAB
:_CAB
echo.
echo.
echo.
set COUNT=0
set C=%COUNT%
echo.
echo.
goto :_Install
echo *******
goto :_Test
:_Test
:_Install
echo.
pause >nul
cls
echo.
echo.
echo.
echo.
pause >nul
exit
:_NoUpdates
echo.
echo.
echo.
pause >nul
exit
well in for it will not run in the first code like you want
it will run like this
set /a COUNT+=1 <<will work fine
set M=1 << will work like that and wouldn't change
so let the for do the job and take the number when it's done
try this one now
@echo off
cls
echo.
echo.
echo.
echo.
echo.
set COUNT=0
for /f %%a in ('dir /b *.msu') DO set /a COUNT+=1
set M=%COUNT%
echo.
echo.
goto :_CAB
echo *******
goto :_CAB
:_CAB
echo.
echo.
echo.
set COUNT=0
for /f %%b in ('dir /b *.cab') DO set /a COUNT+=1
set C=%COUNT%
echo.
echo.
goto :_Install
echo *******
goto :_Test
:_Test
:_Install
echo.
pause >nul
cls
echo.
echo.
echo.
echo.
pause >nul
exit
:_NoUpdates
echo.
echo.
echo.
pause >nul
exit
@echo off
cls
echo.
echo.
echo.
echo.
echo.
set COUNT=0
set M=%COUNT%
echo.
echo.
goto :_CAB
echo *******
goto :_CAB
:_CAB
echo.
echo.
echo.
set COUNT=0
set C=%COUNT%
echo.
echo.
goto :_Install
echo *******
goto :_Test
:_Test
:_Install
echo.
pause >nul
cls
echo.
echo.
echo.
echo.
pause >nul
exit
:_NoUpdates
echo.
echo.
echo.
pause >nul
exit
The script found updates, but no read ho many MSU files are in folder... For CAB files it work...
mm that is wired
try to replace if exist Windows6.1-*.msu with if exist *.msu
and remove @echo off
and make a pause after each section so see if it works fine or not
mm that is wired
@echo off
cls
echo.
echo.
echo.
echo.
echo.
goto :_USRCH
:_UOK
echo.
echo Windows 7 Updates Installer found %COUNT% * MSU * Updates
echo.
goto :_CAB
echo *******
goto :_CAB
:_USRCH
for /f %%a in ('dir /b Windows6.1-*.msu') DO set /a COUNT=%COUNT%+1
goto :_UOK
:_CAB
echo.
echo.
echo.
goto :_CSRCH
:_COK
echo.
echo.
goto :_Install
echo *******
goto :_Test
:_CSRCH
for /f %%b in ('dir /b *.cab') DO set /a COUNT=%COUNT%+1
goto :_COK
:_Test
if not "%MSU%" == "1" if not "%CAB%" == "1" goto :_NoUpdates
:_Install
echo.
pause >nul
cls
echo.
echo.
echo.
echo.
pause >nul
exit
:_NoUpdates
echo.
echo.
echo.
pause >nul
exit
Now it work, too many goto and ifs for this small appz :sweatingbullets:
EDIT: There must be a mistake in MSU code... In Folder with 19 msu files it say 1 updates found, but in folder where are 2 CAB it say 2 updates found
great for you :thumbsup_anim:
hmm seems that the if can't run for in it if it got two many lines
"i will note my self next time"
well you can small it a bit with a call function mode
if you want i can make the same cmd but with function and other commands
you will find it less
<< if you want >>
edit:
about your edit
try it this way
if exist *.msu (set MSU=1
goto :_USRCH
:_UOK
echo.
echo.
goto :_CAB
echo *******
goto :_CAB
:_USRCH
for /f %%a in ('dir /b *.msu') DO set /a COUNT=%COUNT%+1
goto :_UOK
Now it allready work :naughty:
@echo off
cls
echo.
echo.
echo.
echo.
goto :_USRCH
:_UOK
echo.
echo Found %COUNT% * MSU * Updates
echo.
goto :_CAB
echo *******
goto :_CAB
:_USRCH
for /f %%a in ('dir /b Windows6.1-*.msu') DO set /a count+=1
goto :_UOK
:_CAB
echo.
echo.
goto :_CSRCH
:_COK
echo.
echo Found %COUN% * CAB * Updates
echo.
goto :_Install
echo *******
goto :_Test
:_CSRCH
for /f %%b in ('dir /b *.cab') DO set /a coun+=1
goto :_COK
:_Test
:_Install
echo.
set /a TOT=%COUNT%+%COUN%
echo Found totaly %TOT% updates
echo.
echo.
pause >nul
cls
echo.
echo.
echo.
echo.
pause >nul
exit
:_NoUpdates
echo.
echo.
echo.
pause >nul
exit
Thanks for your help Darky ;-)
