Posted September 20, 200916 yr Hi all,Thank you very much for reading my post..I have been using win 7 since its beta release , its a great OS... i had burned the win7 ISO downloaded from MS website on an DVD R/W and that is the only copy i have with me..the problem i am facing is that i am not able to make another copy of this DVD (as the R/W has several scratches on it)Whenever I try to do so it stops giving an error.Burning utilities used: Nero 7 , 8 and ImgBurnOS: Windows 7 x64 UltimatePC: Dell Studio 1555DVD brands I tried: Sony , Toshiba, Moser BaerAlso the DVD Drive is functioning normally and i am able to write DVD/ CD . Thanks for your help
September 20, 200916 yr Yea I can relate, I had two DVD RW's and they finally gave out...where I live I cant for the life of me find another dvd rw for sale to save my life
September 20, 200916 yr Jatti, Can't you just download the RTM again and reburn to a DVD-r (not r/w)? Didn't you keep a copy of the .iso?Your other option is to clean the scratched disc. As long as the scratches don't reach the dye layer, the plastic outer layer can be polished. I've fixed several scratched discs using normal toothpaste as an abrasive (don't laugh! It works.)Yea I can relate, I had two DVD RW's and they finally gave out...where I live I cant for the life of me find another dvd rw for sale to save my lifeRick, do you need the drive itself or DVD/RW discs? PM me. Edited September 20, 200916 yr by Mr_Smartepants
September 20, 200916 yr guys,why dont u use a usb key? there is litteraly tons of info on the web:http://www.blogsdna.com/2016/how-to-install-windows-7-from-usb-drive-without-windows-7-iso-dvd.htmhttp://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/http://www.raymond.cc/blog/archives/2009/09/09/how-to-install-windows-7-faster-using-usb-flash-drive/just to name a few.(yeah i know this dosent give you back ure damaged disc)i myself havint done it that way cause ive ben able to do it in a snap with ultraiso.
September 21, 200916 yr Author Thanks to all for their repliesJatti, Can't you just download the RTM again and reburn to a DVD-r (not r/w)? Didn't you keep a copy of the .iso? I don
