[Request] How to make XP 32bit & 64bit in one CD or DVD ?
hello . i am working in Eli lilly and company in Computer management section i am using XP 32bit on some coputers and ohers i am using XP 64bit.
i am so tired from ejecting cd .... inserting cd.....
so i decide to have a CD includes these tybes of windows xp so i spend less time less effort ..
so any one can help me
and thanx advance :thumbsup_anim:
well i don't know how exactly
but the way is using any tool to make a boot menu
like Easy Boot
and integrate in it the boot for both 32 and 64
and then burn then to on dvd
but i don't know how
it's easier to do it in Vista and 7
but xp it's a bit hard :sweatingbullets:
Since this is a company. If all the computers are the same modlels, why don't you make images? Not sure who your company is setup though. The one I woeked for all the PC's were the same so images were used.
i think you can do with Magic Iso
your words `s right LUZR4LIFE
but i don`t know how to use ghost unfortunately
I use Acronis True Image and it's easy. I want to try out Ghost though.
I wouldn't bother with Ghost. It's crap!
I use Acronis true image and it's very nice. It has a free trial too.
To build a multi-os disc, you can try Siginet's PowerPacker. It hasn't been updated in a while, but I use it and it works great. I don't know if it works with x64 though.
For you is easy all, coz you speak every day in english ;) For our isn´t all easy ;)
Edited by George King
